Jacking Question For Newbie
Old Aug 6, 2006 | 06:33 PM
aschiftner's Avatar
aschiftner
Default Jacking Question For Newbie
Hi all. I'm a new 2002 coupe owner and I will eventually jack the vehicle for brakes and oil changes. Hopefully that is all I'll need it for.
I did a search and couldn't find what I'm looking for.
Forget ramps and hydraulic lifts. What do you use that it efficient and effective? The car has not been lowered.
I'm thinking a 2 or 5 ton hydraulic jack with 4 jack stands (how tall??)
Thanks Alan
Old Aug 6, 2006 | 07:55 PM
rws.1's Avatar
rws.1
I use a 3.5 ton jack
4 standard jack stands...
here is the way I jack My '01
http://forums.corvetteforum.com/show...s&forum_id=103
Old Aug 6, 2006 | 09:16 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
This is a great writeup, use it!
Old Sep 10, 2006 | 10:32 PM
Streetgrime's Avatar
Streetgrime
Can someone answer a question for me with a simple YES or NO?
I want to paint my calipers, while they are STILL attached to the car. All I want to do is:
Remove the wheels
Paint the Calipers while they are still on the car. (ive been inspired by FINE99)
NOW.. my question is.
Can I just stick my hydraulic jack under the REAR or FRONT side rail and jack the car up?
THEN take off the wheels, one at a time and paint them?
Jacking up the WHOLE car on stands seems a tad overkill for what I want to do.
I have ONE hydraulic jack.. and thassit
Old Sep 10, 2006 | 11:05 PM
Oldvetter's Avatar
Oldvetter
Remove the wheels
I painted my calipers on the car, jacked up all 4 wheels. I am glad I did, it took 4 coats with a brush. I just kept going around car.
Old Sep 10, 2006 | 11:23 PM
mfrejek's Avatar
mfrejek
NO.
Unless you use the proper jackpad and lift the car at the appropriate location. Hope this isn't too long an answer for you.
Old Sep 11, 2006 | 01:08 AM
Streetgrime
Originally Posted by mfrejek
NO.
Ok, so I was a tad vague.
I WILL use the hockey pucks....
and..
I will use the points on the side of the car specified by the manual.
but no jackstands... I am just gunna jack it up and leave it on the hydraulic jack
Old Sep 11, 2006 | 01:33 PM
mfrejek's Avatar
mfrejek
Old Sep 11, 2006 | 01:54 PM
UncleFodder's Avatar
UncleFodder
I've read your write-up several times, and need to ask a question to confirm something: The 'spanning' wood pads you created for the front and back (look like wide U's) - is the wood strong enough in the center? It would seem like the open area above could be prone to collapse.
I really want to build these, but seeing as were talking about supporting a lot of weight, I wanted to hear any assurances that you see no buckling or flexing.
Oh yeah, these would be a great addition to the EG wood ramps I built this weekend!
To Jacking Question For Newbie
