Textraila Or Spec 3+
Old Aug 8, 2006 | 11:54 PM
Darkness's Avatar
Darkness
Originally Posted by RPO_Z06
I've driven his car and you can't drive it without the whole rear suspension feeling and sounding like its about to be in pieces from all the chatter, he has tried every variation of driving to try to overcome this with no success, it does grab but thats all it does (off/on), the pedal pressure is more than my TEX and the release is lower, the SPEC would be great for nothing but 1/4 mile but he drives his car everyday and so do I, I'm happy I'm not the one stuck with the SPEC all the drivability issues would make me crazy..
Thats because he doesnt know how to drive it yet, its a high performance on/off clutch. You cant slip it like a normal clutch or else it will make all that vibration because the clutch it self is bouncing off the flywheel trying to stick to it. Kind of like wheel hop on some IRS cars.
Have him start in 2nd instead of 1st and see if it still does the same, if it does then its a bad install, if it doesnt then he just needs to get used to it.
All I care is for when I shift at 7100rpms my clutch wont spin and my spec doesnt.
Old Aug 9, 2006 | 01:08 AM
killaz's Avatar
killaz
Im at 430Hp and have had the clutch in for around 3,000miles. I drive the car very hard, and have had zero proplems with my TEXTRILLIA clutch. If i were to do it again i would buy the same. I do nothing but drag racing, so, so far so good.
HOLLA
Old Aug 9, 2006 | 09:11 AM
willyfastz's Avatar
willyfastz
I agree, people buy a racing clutches and exspect them to drive like a stocker. He should have got a Spec 2 or 3 instead of the 3+.
Old Aug 9, 2006 | 09:37 AM
WKMCD's Avatar
WKMCD
There are a couple of stories about the Spec coming apart and tearing the firewall off the car. So far no limbs.....
Go witih the Ausie clutch.
Old Aug 9, 2006 | 09:40 AM
willyfastz's Avatar
willyfastz
You should get the full story on those two cars.
Old Aug 9, 2006 | 12:30 PM
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
We're both aware of the high performance aspects of these clutches hence the reason for needing one of them in the first place but the fact remains my car launches like a rocket without any slippage as his does but drives ten times better while doing it, I shift anywhere from 6700 to 7000 RPM.
I'm not giving some bias facts to make my clutch sound better it just is.
I could have just as easily bought the SPEC and him the buy the TEX at which point I would be the one dealing with all the issues he's dealing with.
Bottom line is SPEC touts the Stage 3+ as a driver friendly hybrid clutch and its far from it.
And I'm not a anti SPEC person, I've had them before thats why it was one of two of my choices.
The Aussie's simply did a better job building a clutch, end of story.
_
Jamie
Old Aug 9, 2006 | 03:56 PM
jbusmc1986's Avatar
jbusmc1986
St. Jude Donor '06
I had a textralia clutch in my 98 ls1 camaro, and it was really good through the break in period, but after about 10k it developed a really bad chatter and would not fully disenguage, My dad (I sold him the car) is trying to figure out those issues right now.... I am going with the spec 3+ and I will let you guys know what I think about it when it is done
Old Aug 9, 2006 | 08:43 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
We won't shoot the messanger so go ahead and tell us Specs side
Old Aug 9, 2006 | 11:30 PM
willyfastz's Avatar
willyfastz
Seems that one of them was a flood car from Katrina that sat under water for a while. Tech at spec said they offered to bring the cars there and dissasible them and niether owner would agree. I forget what he said about the other car, something about the rear locking up. There's always two sides to every story, which one is true I don't know.
Old Aug 10, 2006 | 10:32 PM
Darkness's Avatar
Darkness
The fact is that people like me have the spec 3+ and dont have those issues and they work just fine and then people like your friend have them, therein the point that I made that it was either a bad install or a bad break in.
Either way, I'm sure he can sell it to someone else who will enjoy it.
Old Aug 11, 2006 | 08:50 AM
JoeyG's Avatar
JoeyG
Cruise-In IV Veteran
Originally Posted by mainagent
ChiefDave... Are you able to slip the Tex a little bit in daily driving or is it an on/off deal?????
To get my TSP MS4/Stage 2.5 headed motor moving I need to slip my Textralia a little, it holds up well. From a dig racing it's like a f)ing rocket
Old Aug 11, 2006 | 04:34 PM
Jeffs FRC's Avatar
Jeffs FRC
First thing to check is the pressure plate bolts. They need to be torqued to 55 ft.-lb. and you also should have used red loctite. Another good idea is to remove the paint on the pressure plate where it bolts up to the flywheel.
I dont have a Spec so I cant comment first hand, but I have heard mixed results. It seems that about 95% of Tex owners are extremely happy with there clutch. That is saying something.
Ive just installed a Tex and have about 150 miles on it so far. There is very minor chatter, but as its breaking in its going away nicely. Behaves very nicely on the street and you can slip it off the line. Not an on/off switch like the Specs I have heard about. Also I have the z grip disc which is more aggressive than there standard x grip. Id imagine the x grip is even more tame than mine.
Pretty sure Ive heard that the Tex's are good for about 700rwhp.
Oh, if you want the stories about the exploding Spec cars head on over to LS1Tech and do a search for "Spec" in the manual trans section. There is lots of good info on clutches over there.
Jeff
