Help! Tightening CV boot clamp
Old Aug 8, 2006 | 10:55 AM
ericdwong's Avatar
ericdwong
Default Help! Tightening CV boot clamp
OK guys I'm gonna ask here before I run to the store and buy a different style CV boot clamp. I'm doing the outer CV axle for my C5 and the kit is a factory kit. The inner CV clamp I am familiar with, I have the tool that puts the kink in the clamp to tighten it down, it is the same one that is pictured in the factory service manual. however the larger clamp is completely different. I see nowhere to put a tool onto it. There is no kink to make tighter. How do I use this style CV clamp???
Old Aug 8, 2006 | 11:21 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Eric, i don't have the answer, aren't the new axles $220 new from GM? how much for the rebuild parts
I do see a lot of torn boots, even on low mileage '02/'03's, always seems to be the pass side, makes a real mess when breaking down the suspension
interesting question
did you try www.rpmtransmissions.com , Rodney usually has answers
Old Aug 8, 2006 | 12:51 PM
3rd Childhood's Avatar
3rd Childhood
Don't buy anything. If I can figure out how, I'll post some pictures showing how to install a low profile clamp. Hopefully the tool you used on the small clamp will work. Patience.
Old Aug 8, 2006 | 01:44 PM
3rd Childhood
PM sent.
Old Aug 8, 2006 | 03:09 PM
ericdwong's Avatar
ericdwong
Sent email, thanks in advance, I love this forum. I did pick up another style clamp, but it was only a $2 part, so I'll wait for instructions..
Old Aug 9, 2006 | 06:50 PM
3rd Childhood
Default Low profile boot clamp
Try to use the low profile clamp as it provides proper clearance and is more robust. Here are 3 pictures which show the steps and a tool which will work. This isn't the Corvette clamp. Happens to be a Toyota clamp but the idea is the same.
Old Aug 9, 2006 | 07:52 PM
sugarwolf's Avatar
sugarwolf
I changed mine and i said hell with this clamp, its liek they sent me a too small of one, i do have the band pliers but would not clamp up right. So i used a strap tie and hasnt caused any trouble at all..
Old Aug 9, 2006 | 08:14 PM
ericdwong's Avatar
ericdwong
Awesome tip. My damn tool I have does not open far enough to get to the clamps.. ugh!
To Help! Tightening CV boot clamp
