I think those are adjustable Harland Sharps. They make both varieties. There are 3 things to consider when changing to aftermarket rollers.
1) The moment of inertia is usually larger. Even though the roller helps with friction due to more weight at the tip from the roller wheel and bearing. Consequently the inertia is a little greater.
2) If you go with a higher ratio rocker you will increase the acceleration characteristics of the cam lobe.
Both of these items will decrease the stock springs' ability to control the valve train at high rpm's. If you are going to change to aftermarket rollers I would suggest upgrading springs, retainers, and pushrods.
3) The third item is interference. Some aftermarket roller rockers have clearance problems with certain heads for one reason or another. I had to clearance my heads for the Harland Sharps and hog out my valve covers and machine the Jesels for retainer clearance. I have read that others have done this and others have been fine. Bottom line here is you have to try to fit them and if you are lucky, they fit, if not it's time to take out the die grinder.
I've used both Harland Sharp and Jesel 1.7 roller rockers on my AFR 205's. They are both good products and I have had no problems with either one other than interference.
I should buy new push rods and valve spring + retainers
If they are made for stock LS1 heads there should be no interference ?
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Yes, the AFRs are aftermarket.
I had the Harland Sharps and concur with ArKay99 - I had minor interference with the heads (removed about 0.10inch with a Dremel) and had to canabalise my valve covers to clear them.
