I just installed the predator I received today and it really made a nice difference which I feel was worth the money, but there's one small glitch. The oil gauge now always shows maximum value once the engine is running, and doesn't read accurately anymore. Once the engine is turned off, the oil gauge again returns to zero, but once it's restarted it goes to maximum and stays there. The directions did say that during the perfomnance tune installation that the gauges might sweep back and forth and other signals might sound, but not to worry, that's normal, so I wasn't too concerned when I first saw it maxed out during the installation. Is there a fix for this???? Or did I blow my oil gauge?
Its your oil pressure sender switch behind the manifold. Did it to me and a million others.. Mine says i have 125lbs pressure all the time.. Shucks has them for around 39 bucks
Strange coincidence but I had my gauge go too. You have to remove the intake manifold to change the sensor. Actually, this is really a poor engineering decision where the sensor is located. On distributor equipped small block V-8's the sensor is located next to the distributor. On the LS motors we know there is no distributor, but they kept the switch in the same location. For accessiblity reasons, I have no idea why they didn't relocate the sensor making it easier to repair. It would save them service money since most people aren't going to do the repair themself.
From: Alhambra Calismognazifornia, in the country everyone comes just to complain but won't go back home!
pure coincidence....look at the reading in the DIC, it'll show 134psi...mine just went out on me on this past saturday while driving to vegas. you can bet that made me more than a little nervous out in the middle of the desert in 110 degree heat!
To bad they didint locate it by the oil filter where the temp gauge is like the big block chevys.
So it's definitely not related to the predator tune? I don't suppose that I could uninstall and reinstall the performance tune and see if that might correct it???
definitely not, the predator does nothing that'll boost your oil pressure.
but, if it'll give you peace of mind, go ahead and turn back the tune. your stock tune is stored in the Predator's memory. Just plug it in and tell it to return to stock tune. once you're satisfied that that the meter is still pegged, reflash the performance tune and get to work replacing the bad sending unit.
Looking at the great link to the tech tip on how to r&r the sending unit, it doesn't look too hard. I am tempted to try and just slide the manifold forward a few inches as some have done and thereby reach the sending unit, but I'm worried about accidentally dumping some gravel or other debris on the manifold/head surfaces into the intake ports of the heads. Also, when sliding the manifold back into place some small particles (or not so small) might get trapped between the intake manifold gasket and the head surface, thereby causing an air leak. Very bad for business, as I recall from an engine rebuilding class I took at community college in the 70s.....
Is that a rubber gasket I see in the photos of the intake manifold??? Therefore reusable?
[QUOTE=Gene Wolf]...but I'm worried about accidentally dumping some gravel or other debris on the manifold/head surfaces into the intake ports of the heads. Also, when sliding the manifold back into place some small particles (or not so small) might get trapped between the intake manifold gasket and the head surface, thereby causing an air leak. Very bad for business, as I recall from an engine rebuilding class I took at community college in the 70s.....QUOTE]
aha! now we're on the same page
i was just looking over the how-to write-up last night myself (since mine needs changing too) and was wondering the exact same thing!
Yes, the intake gasket is reusable. Its not really a hard job at all, I still like to have the intake out of the way to get to the sensor. Pay attention to the tourqe setting, your current wrench may not go that low and people swear that it has to be the right tourque or it will fail quickly. Also, I've heard that the borg warner brand of the sensor is better than the delco. Its easy to find, got mine at NAPA and its already lasted 3 times as long as the delco unit (which is only a few weeks)
would blowing off the engine with a compressor hose be sufficient, or should you wash down the engine to get all the grime and stuff out of the area before pulling the intake?
I'm leaning towards the 'ol air compressor and vacuum combination where the vacuum is right there to suck up the debris the compressed air kicks up.... Just paranoid about grit around internal engine parts!
