Security Light
Old Aug 9, 2006 | 02:22 PM
BosqueVette98's Avatar
BosqueVette98
Default Security Light
Last night while driving home from work the security light came on. I pulled over in a parking lot turned the car off, restarted with no problem and the light was off.
Any ideas what might have caused it to come on?
Thanks!
Old Aug 9, 2006 | 02:48 PM
Oldvetter's Avatar
Oldvetter
Did the key get wet?
Clean the key (resister).
Old Aug 9, 2006 | 03:55 PM
bighank's Avatar
bighank
Default security light
Mine comes on sometimes after a start.
Usually off next start.
No codes stored.
Anyone explain this ?
Mine is a 98' C5
Old Aug 9, 2006 | 05:11 PM
BosqueVette98
Nope, key is/was clean & dry. The light just came on after about 20 minutes of driving...
Old Aug 10, 2006 | 03:55 AM
David426's Avatar
David426
Electrical Gremlins.. Mine did this just a few weeks before the battery went dead. Replaced Battery and everything was fine. Are the two related? I don't know for sure.
Old Aug 11, 2006 | 06:30 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Do you have the stock alarm or an aftermarket?
Old Aug 11, 2006 | 10:30 PM
cbota's Avatar
cbota
I had a simular problem and it was caused by the ac drain tube being clogged. Water then remained in the duct, then when making a left turn the water flowed to the passenger side and leaked out the blower motor vent. The water lands on the BCM, and some relays(anti thieft, column lock). I cleaned the vent and the water and problem seem fine.
To Security Light
