Can anyone tell me why?......
Are there really that many "factory freaks" manufactured by the General running around out there? Was I one of the 'unfortunate' ones to have purchased a "factory dog"?
So far, I have a 228/222 588/581 @ 114 Comp cam...LS6 (Z06 243) heads...underdrive pulley...SS Works Long tube headers...low restriction 3" mini-cats...H pipe...Z06 Ti catback exhaust...and a Blackwing intake, on an '04 Coupe with A4 tranny.
Three different Dynojets in three different states, say I am putting down 369hp and 354tq to the pavement. All three dyno operators say that is about what I should expect for my mods.
I do understand that a six speed will produce a little higher figures due to the lessor driveline loss, but THAT much of a difference?
What about the A4 vettes that are in the 400hp range with the same mods? What gives with all those 390-420 hp claims? Am I being lied to?....and if so, by whom?....the dyno ops, or those with the extraordinarily high output figures?
I'm getting so frustrated with all this stuff, I'm about ready to throw in the proverbial towel with this Vette and move on to something else. I'm tired of spending all this money, and always finding myself at or near the bottom of the figures heap.
Sorry for the rant...but this is just really getting to me.
So you can figure out what the differences are with your setup.....
DH
Just curious but would the gearing in the rear end have much of an effect? I've got a 2000 with the 6 speed and minor mods and dyno at 321hp and 335tq. I've got the 342 rear gears where the A4 guys have 273's. They usually run 10-15 hp lower than me.
Kelly
Kelly
I asked that very question in an earlier thread, and the general concensus was that what 'differences' there are between different rear end ratios is negligable. The peak numbers will most likely come in at a higher RPM with the 2.73 gears, than say a 3.73 equipped vette, but the figures themselves should remain virtually the same.
Thanks for asking though...it was a good question.
So you're suggesting that your additional 50 hp over mine is due to your having ported and polished heads of similar configuration? Is that a reasonable claim? I'm not trying to be a SA here, just trying to learn something.
Someone else may have an opinion on the matter.
Chris
DH
Hmmm, you had more air coming in.......and I would assume about the same exhaust set as mine. From that, I am to conclude that is what accounts for your additional 50hp and 40 tq? Just more air?
So what's the actual limiting factor here?.......Personally, I would say it would have been the cam......but that's apparently not it, because WITH that cam, you put some highly respectable power.
The only this left are the heads, right? Is it safe to say that I erred in having these Z06 heads put on......and that I should have either modified them or put on something different and THAT would make up for the 50 lost ponies I don't have?
I asked my tuner/installer that very same question and he told me that it would be a waste of time and money, what with the cam I have in there......that the cam would hold back whatever gains in airflow I would have benefitted from with larger flowing heads.
It seems I can never get a majority to agree on anything when it comes to these sorts of mods, (no disrespect intended to you, of course). Just making an observation.
I simply don't have the resources to continue on with all this "trial and error" sort of thing that's been going on so far. Surely SOMEONE eventually has "gotten it right", to where this info could be passed on to a dummie like me.
I realize right now, I have been 'all mouth'......now, I'm 'all ears'.....teach me what I need to know.
Then again, I ran a 11.11 with 388rwhp and 11.05 with 397rwhp. So dyno numbers really shouldn't be your biggest concern.
I've got a larger cam (232/236) and M6/4:10's and I dynoed at 420, but my torque is only 358 at the rear wheels.
As soon as it cools off a little I'll see how I do in the 1/4.
Bob K.
As soon as it cools off a little I'll see hot I do in the 1/4.
Bob K.
I too am going the the track Saturday to see what it will do. When trying to hone my launch technique, I noticed something really strange. I started a new post here about that.
Maybe you'd like to take a look and offer an educated opinion.
As far as the dyno numbers, yeah I realize they are only good for before and after tuning purposes....but still, my numbers seem really pathetic in the shadow of some others here with about the same set-up.
Thanks for the response, for ALL the responses, for that matter. Every little bit helps.
Why did you go with a reverse split cam? Most guys go with a longer duration exhaust lobe than intake.
Tune. What amount of timing advance are you running, what's your A/F, and are you getting KR?
Engine/tranny/diff temps. You want to make the run with a cool engine (160 to 190), but with the tranny and diff up to temp so the lubes are not so thick and flow better.
Good luck, hope you get some results you like
I have never quite understood the logic and reasoning behind degreeing more air in to the comb chamber than is being exhausted. Makes absolutely no sense to me.
I'll let y'all know how it goes at the track on Saturday. Temps are reported to be in the low to mid 80's, and of course you probably know about what kind of humidity we have here in Iowa.
Also, it's a long shot but.... have your injectors cleaned. If one is clogged it could cause the pinging by allowing that cylinder to go lean. Then the PCM will cause the rest to be fat so it gets the combined A/F it wants to see. And, of course it will reduce timing. Any of the above will reduce power.
On a DynaPack dyno runing short headers, 6sp, 3:42, stock LS6 heads (with upgraded springs & rods), 220/220/114 cam, I dyno'ed 378 hp & 372 torque. My cam is about as puny as you can get and still call it a mod.
I think you are correct, you should be posting better numbers. Because of the limitations of the LS6 head you probably won't see a realistic 400, but 385 - 395 rwhp I feel is the neighborhood you should be hangin in.
I'm not a mechanic and you obviously need to talk with some specialists. My gut is telling me it would be best to find out more about why your making low power before you max out your componets at the drags. If something isn't correct, now would be the best to find it and fix it.
good hunting
Could be the tune or lack of ported heads with attending springs.
Good luck.
I went with the Comp 918 springs and chrome/moly pushrods, along with the 243 heads.
It would seem that the overall consensus now is leaning in the direction that the heads need to be reworked to improve the flow characteristics.
As far as 'stressing' the existing components, I think I've got them all pretty well "broken in" and adequately "tested". If something was going to break, it would've done it by now.
So, it's off to the races Saturday, and afterwards, see if I can get lined up somewhere and get those heads worked on.......and get some 3.15 gears put in while I'm at it.
Don't anyone be giving me grief about that now....I'm positive I don't want 3.42's. Thanks all for your help.
