Brake upgrade-SS lines
Old Aug 9, 2006 | 05:56 PM
Kal-El's Avatar
Kal-El
Default Brake upgrade-SS lines
I am upgrading my rotors and pads and would like to do the SS brake lines at the same time. I have read about different fittings and it seems AN fittings are better than Banjo. Anybody recommend any particular brake line? What length is the C5 brake line?
Thank you
Old Aug 9, 2006 | 07:08 PM
tiojames's Avatar
tiojames
Default SS lines
Do a search on brake lines and you will find a number of companies. I went with Summit and only had to slightly bend the lines right behind the caliper to have them work on the C6 Z06 brakes. If you have stock calipers I think any of the kits will work with no problems. I don't know the lengths, but the rears are about 2" longer than the fronts.
Old Aug 9, 2006 | 07:54 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
I recommend the Goodridge SS Brake Lines. I read that one or two particular brands caused the DIC to display error codes. The Goodridge work perfect!
Old Aug 9, 2006 | 08:21 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Earl's works for me
Old Aug 9, 2006 | 08:37 PM
jfrc's Avatar
jfrc
on sportbikes, you can feel the difference with new lines
is it the same here? would they be worth it for autoX?
Old Aug 9, 2006 | 09:39 PM
LoneStarFRC's Avatar
LoneStarFRC
Several different vendors sell the Goodridge kit. It is complete and fits perfectly. I've had mine for a couple years now. Not a thing wrong with banjos. HTH
Old Aug 9, 2006 | 09:59 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
www.dougrippie.com the difference is not huge in feel. Slightly possibly.
Old Aug 9, 2006 | 10:28 PM
VetteDrmr's Avatar
VetteDrmr
I've been autocrossing my Vette for almost 4 years now, and have never felt the need for SS brake lines. Invest in a pad upgrade and tires before you ever think about line upgrades.
HTH, and have a good one,
Mike
To Brake upgrade-SS lines
