dtc p0157
Old Aug 10, 2006 | 12:11 PM
itchy_c-5's Avatar
itchy_c-5
Default dtc p0157
I've been getting a DTC code P0157. Anyone have any ideas?
Old Aug 10, 2006 | 12:22 PM
Silver98's Avatar
Silver98
from the service manual (1998): HO2S Ckt Low Voltage Bank 2 Sensor 2
I believe this is the passenger side aft of the cat.
The PCM sets this code:
the vehicle runs out of fuel
HO2S wire: Sensor pigtail maybe in contact with the exhaust manifold or exhaust system
The wire may be broken
intermittent ground in signal wire between connector and sensor
Lean injectors
Fuel contamination
Low fuel pressure
Exhaust leak near the HO2Scan cause a lean condition. Vacuum or crankcase leaks can cause a lean condition.
So, I guess you have a little bit of diagnostics to do. Others may have more relevent information for you.
HTH
Old Aug 10, 2006 | 01:06 PM
itchy_c-5's Avatar
itchy_c-5
Is there a way to test my fuel pressure?
Old Aug 10, 2006 | 02:05 PM
Major Smoke's Avatar
Major Smoke
Fuel pressure guage can be connected directly to the schrader(sp?) valve on the front of the fuel rail.
To dtc p0157
