Catalyst System Low Efficency
Old Aug 10, 2006 | 07:12 PM
stormrider's Avatar
stormrider
Default Catalyst System Low Efficency
My engine light came on yesterday so I ran the codes to see what might be wrong and I got code P0430 H C which to my understanding is a "Catalyst System Low Efficiency" history and current code. I noticed a whiff of that rotten egg smell, not bad could just barely make it out during acceleration. Does this mean that I need new cats, the car has 51K? If I do should I go with high flow cats in preparation of installing headers in about 6 months and finally how much HP do high flow cats give you with headers over stock cats?
I know lots of questions for one thread but I have always gotten tons of good advice on here so I thought I would go to the well again
Old Aug 10, 2006 | 08:17 PM
RonSS's Avatar
RonSS
If I was going long tubes and high flow cats in 6 months I'd just clear the code every few days. Generally a 430 does mean it's time for a new cat(s) so spend your hard earned cash on the high flows and not another set of stock cats.
Old Aug 10, 2006 | 09:42 PM
vettenuts's Avatar
vettenuts
If you go with headers, a tuner will likely delete the 2nd O2's anyhow, why both fixing it at this point. You could have it turned off now or wait. Another approach is the center cat pipe is all one piece, there are guys literally giving them away. You might be able to pick one up cheap or free in the for sale section.
Old Aug 10, 2006 | 10:11 PM
Anthony01's Avatar
Anthony01
If you go by GM flow chart for that code, it states to check for damages converter and H02 sensor. If all looks ok, then replace converters.
You can get them replaced under warrenty, due to that fact they fall under the Federal Emission law. They are covered for 8yrs/80K whichever comes 1st. same for your PCM. It will have to go to the dealer for the fix, but it should not cost you
That is how it is at my dealer and I'm in St.louis, and are smog laws are not that Hitler .
Old Aug 10, 2006 | 10:32 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Same happened to me here in Ca.,took it to the dealer with only 1 week to go on the warranty!
Took care of it,.........new cats, no cash!
The bill was around an inflated $1,000 from the invoice They actually replaced the entire midsection
Old Aug 11, 2006 | 02:46 PM
BuffC5's Avatar
BuffC5
This means your stock cats are toast.
I had a similar problem, but made the mistake of gutting them....DO NOT DO THAT!!!
Anyway, I hit up www.dezod.com, scooped some Melrose long tubes and Random Tech X-pipe w/ cats to keep it emissions legal for good ol NYS.
Old Aug 11, 2006 | 05:45 PM
PVHolgado's Avatar
PVHolgado
I installed DynaTech SuperMaxx LT's w/ hi-flo cats still got the 0430 code tuner just turned off rear O2's Everything is fine now..
To Catalyst System Low Efficency
