this is my second set of tpis and the air tubes keep breaking. anyway I need to know what to look out for when installing these things cause I've heard these headers are a little tuff to install.
Patience is the most important thing, you will swear that they will not fit, I assure you they will go in. Remove the alternator, steering linkage, (don't turn the wheel) plugs, wires, be careful of or remove the coolant sensor, pull the vacuum line from the brake booster. I found that un-bolting the motor mounts from UNDER THE CAR gives you a bit more room. You will have to jack up or pry over with a 2x4 the engine so the headers can drop in. It sounds like a PITA but it's really not bad at all.
