Clutch engagement question
Tino
With that in mind, here are three clutch fluid issue threads to review:
Clutch Pedal Woes--Fluid Impact
C6Z06 Clutch Hydraulic Fluid--the Chevy Spec
Clutch Pedal Woes--Fluid Changing Kit
Ranger
Excellent information, i will seringe the brake fluid out and replace it with fresh fluid to see if that helps....
When you fill with fresh fluid, the full line is delineated by a slight "shoulder" line on the inside of the reservoir, which you can feel easily with your finger. Correct fill is important.
Good luck and let us know what you find.
Ranger
Ranger
I am filling it with Valvoline Synthetic.. DOT 3/4.. I picked up a quart of it at Discount Auto for $6..
Keep you posted..
Keep you posted..
It will leach to black almost immediately and make the clutch pedal squeak like a ****. It's the only brand I've consistently recommended against, for those reasons.
Ranger
Will do, I checked the fluid today and it is has a black to charcoal color to it? Doesn't sound like the color it should be, I will definitely keep replacing the fluid until it is clear
Tino
It's not gonna matter much.. I plan to install a Cartek clutch very shortly...
Here is an update, I went to my dealership today and they recommended a new clutch, they even suggested that they would replace my regular C5 clutch with a Z06 unit. They also offered to go have a look at my tansmission re: reverse, etc and replace whatever is needed. They said my factory warrantly would cover every cent of this. They asked me to drop it off in the fall when I put the car away for the winter. Do you think I should do this? The drive train specialist there agreed that it was engaging high but said the fluid replacement would not correct the issue? All coming at me real quick, decisions, decisions, decisions?
Tino
Here is my usual clutch replacement advice:
Four small suggestions to those wishing to swap out their clutches.
(1) Seach the archives (C5 Z06 and C5 Tech) for the words "clutch" AND "vibration" because there is a history of clutch swap woes you need to be aware of.
(2) Choose your installer carefully. If you don't, the odds are good that you will not be happy with the results. You want a technician with a lot of (favorable) experience in swapping C5 clutches.
(3) Insist that the new clutch assembly be sent to a reputable machine shop for balancing before the installation. Do this even if the installer insists it's unnecessary.
(4) Before you drop your car off for the installation, be very careful to memorize how much your shifter vibrates under various conditions.
If you choose to shrug and ignore this advice, the odds are that you will end up with notable drive train vibrations, originating from the clutch assembly, and you will have a hard time getting them resolved by your installer or anyone else.
From six years of reading CF and experience in changing clutches in two Z06s, I've learned to exhaust the no-risk steps (fluid changes or bleeding) before taking on the risk of an installation. Dealers poo-poo fluid swapping because it makes them no shop hour $$$.
I understand you may choose the installation. If so, whatever else you do, suggest scheduling it early enough that you can resolve issues before you mothball for winter.
Ranger
Ranger
Thx Tino
