ABS/Traction Syst Warning
Old Aug 12, 2006 | 06:54 PM
jarsdad1's Avatar
jarsdad1
Default ABS/Traction Syst Warning
Two days in a row, when I punched it getting on the turnpike, the service abs and service traction syst. warnings came up. No codes either time. Only happens when I accelerate hard. When I restart the car, the warnings are gone. ???? Thanks
Old Aug 13, 2006 | 03:57 PM
cliff_ford's Avatar
cliff_ford
Funny no codes. Did you check with a scanner or did you use the DIC?
Some scanners don't get all the codes.
Old Aug 13, 2006 | 04:11 PM
GTSLN97's Avatar
GTSLN97
I used to get that warning. After I changed my diff fluid with royal purple, it never came on again.
Old Aug 13, 2006 | 04:31 PM
Lancer033's Avatar
Lancer033
About a year before my EBCM crapped out, I started getting stuff like that. It's possible that is what's going on.
or it could be a simple lose wire. Next time, as soon as it happens, pull the codes from the DIC before you turn the engine off (you can do it while you're driving, but don't blame me if you hit something). There's got to be a code there for the light to come on. For some reason, the TCS doesn't keep the history codes in the DIC once the fault is gone. When I replaced my EBCM, the code went away w/o having to clear it, no history code, no nothing, it just worked.
Old Aug 13, 2006 | 07:31 PM
jarsdad1's Avatar
jarsdad1
Used the DIC for the codes. I'll try to pull them next time the fault appears (while driving).
Old Aug 13, 2006 | 07:39 PM
DeeGee's Avatar
DeeGee
I had a similar problem before my EBCM failed
The captions would come on normally when stationary at lights, particularly with high outside air temps. It would normally throw a C1214 code though
Turned out to be an intermittent EBCM relay malfunction.
To ABS/Traction Syst Warning
