Parking Light
Old Aug 13, 2006 | 06:51 PM
SSWEET's Avatar
SSWEET
Default Parking Light
Need to replace the park light bulb on a 1999 C5...Whats the best way to get to it?
Old Aug 13, 2006 | 07:08 PM
SSWEET's Avatar
SSWEET
Sorry, I gues I mean how do you access the daytime running light bulbs or front turn signal bulbs?
Old Aug 13, 2006 | 07:33 PM
DeeGee's Avatar
DeeGee
You'll get three suggestions
Go in through the brake ducts - not easy with a Z06 or if you have screens
Go in through the bottom by taking out the bottom panel
The one that works for me is:
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job.
The bulb is a 4157NA
Old Aug 14, 2006 | 10:37 AM
SSWEET's Avatar
SSWEET
Thanks for the info...............
To Parking Light
