Clutch Grinding Noise
Old Aug 14, 2006 | 08:49 AM
nikolai's Avatar
nikolai
Default Clutch Grinding Noise
I have a RAM HD Powergrip clutch w/ steel billet flywheel w/ about 1000 miles on the clutch. Lately, the clutch has been making a grinding noise just from daily driving, not even racing it.
When I am in first gear, starting from a dead stop, and giving it a little gas before I release the clutch all the way, it makes a grinding-type noise. Once I release the clutch pedal all the way, the noise goes away. This also happens when I go in reverse.
I know this clutch that I have is supposed to chatter a little, and that chatter is heard, but the grinding is a bit unsettling. Has anyone else experienced this (even with a different clutch) or does anyone have any idea what it might be?
Thanks a bunch ahead of time,
Nick
Old Aug 14, 2006 | 09:17 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Sounds like a bad throw-out bearing.
You could put up on lift and drop inspection cover, then start car while up in air with clutch pedal down to confirm.
If it's bad the whole drive line will have to be dropped to replace it.
Old Aug 14, 2006 | 09:45 AM
nikolai's Avatar
nikolai
That is actually what I was told it might be, but I was not sure. Thanks for the input and I'll look into it.
Old Oct 2, 2006 | 09:21 PM
killaz's Avatar
killaz
did you ever figure it out. Mine does the same thing
Old Oct 2, 2006 | 09:57 PM
TRACKMAN2's Avatar
TRACKMAN2
I Had A Ram Clutch In My C4 It Made An Awfull Noise When In Engaged, I Ran It All Year No Problems ..
Old Oct 16, 2006 | 11:30 AM
raserguy's Avatar
raserguy
Default Grinding
Please let me know if anyone figures this out mine is doing the same thing, grinds first with clutch fully depressed.
Old Oct 16, 2006 | 01:21 PM
Billdog350's Avatar
Billdog350
-1 Point for RAM making grinding noises.....
To Clutch Grinding Noise
