Need Help! Door Ajar Warning
Old Aug 14, 2006 | 12:24 PM
cabanaboy2005's Avatar
cabanaboy2005
Cruising
Default Need Help! Door Ajar Warning
I have a door ajar warning on the dic of my 2000. The codes are below. Before I take it to the dealer (aka Stealer), I would like to be sure it's not something easily fixed like a fuse or relay. Strangely, the tire pressures do not show on the dic like it used to. So, I was wondering if they are on the same circuit, ie; sharing the same relay. I know it's effecting the alarm but that's explainable with the door ajar warning. Does anyone know what fuses are in the door ajar circuit and where they are located. Anyone alse had any troble with this? I have lubed the door latch but no luck. Does it sound like the door switch itself? If so, can it be replaced without removing the door panel? What else could it be?
The diagnostic codes I get are as follows:
BO-RFA U1064
U1016
U1098
Thanks in advance
Old Aug 17, 2006 | 12:18 PM
cabanaboy2005
Cruising
Dealer says bad BCM (internal short) and is installing now. Will let you know how it works out.
