Is there a special way to patch runflats.
Old Aug 14, 2006 | 10:18 PM
Smokin Joe's Avatar
Smokin Joe
Default Is there a special way to patch runflats.
Got a screw in relatively new runflat, firestones. Is there a special way to fix them.
Old Aug 14, 2006 | 10:57 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Patching on the inside is the best way IMO...
VR
Old Aug 14, 2006 | 11:16 PM
b98's Avatar
b98
gasoline & a match, never have a problem with it again.
Old Aug 14, 2006 | 11:24 PM
vetteguy02's Avatar
vetteguy02
My understanding Firestone states their run flats are not repairable. The correct way to repair Goodyear and Michelin tires is to both plug and patch the hole. Sorry to hear about your lost.
Old Aug 14, 2006 | 11:32 PM
JC in XTC5's Avatar
JC in XTC5
I believe they're only unrepairable if you DRIVE on them with no pressure. If you haven't driven on them in EMT mode, they should be repairable by patching from the inside.
If they're fairly new you may have road hazard coverage from Firestone. Call your local dealer and ask.
Old Aug 14, 2006 | 11:50 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Joe,
Best to use a patch with plug (all one piece - sort of looks like a mushroom). The plug supposedly will seal the tread and keep moisture from getting into the tire's carcass.
Old Aug 15, 2006 | 12:36 AM
rws.1's Avatar
rws.1
You will likely need to take it to a local shop.I do not believe a Firestone franchise will repair them.
Old Aug 15, 2006 | 01:01 AM
GrayC5's Avatar
GrayC5
You may have problems getting an authorized Firestone repair shop to repair them. You will just have to check and see. Below is a quote from the article, Run Flat Facts, by Hib Halverson (see about 3/4 ways down in the article):
Next, I contacted Tiffany Bryant, spokesperson for Bridgestone/Firestone USA, and Dan Guiney, spokesperson for Yokohama Tire Company. They told me that the Firestone SZ50EP RFT and the Yokohama AVS Sport Run-Flat are, also, rated for up to 50 miles of 55-mph run-flat operation, however, after any run-flat incident, neither can be repaired and both must be scrapped.
An independent repair shop might possibly repair your tire. If so, the repair as others mentioned above should include both a plug and patch or a combination plug/patch sometimes referred to as a mushroom patch. See following:
Puncture Repairs
Any chance you have road hazard warranty on the tire? Good luck with the repair/replacement.
Old Aug 15, 2006 | 08:16 AM
Smokin Joe's Avatar
Smokin Joe
Thanks guys. They have lost no pressure at all to this point. It happened a couple of days ago.
Old Aug 15, 2006 | 08:44 PM
Gray Weasel's Avatar
Gray Weasel
Default Tire Repair
Have had both Goodyear and firestone fixed....go on line to tire rack and see if they have any recommened tire installer's in your area these places should be able to fix your tire.....run flats are a different animal and need someone who knows what they are doing......if the screw is in the side wall all bets are off they cant fix it....but in the center thread... it should be no problem
To Is there a special way to patch runflats.
