'02 Z06 goes pop
Ronnie
Bill
Thanks Lou for the local info since I have not heard of many shops in the area that people will recommend.
R
That did it. Thanks to all that responded.
R
If you want to solve the problem with the splined hub popping, you will need a lubricant heavier than WD40, and you will need to apply the lube on the inboard side of the spline, not just back the nut off and spray some light lubricant in.
Check this...
http://forums.corvetteforum.com/show....php?t=1422289
This is the part you need to know...
This is a well known problem within the cv joint industry. The noise is coming from the splines, but it is caused by motion between the bearing face and abutment face on the joint which sticks due to friction but then slips as it is overcome by torque. When it slips, lash in the spline connection is taken up in the opposite direction and you hear the pop. This is why many auto companies now use a press fit (created by a helical spline) between the joint and hub.
As I mentioned earlier the same can happen within the bearing but this is much less likely. The best way to solve your problem is to lube the other end of the spline as this will let lube get between the bearing and the joint. This will prevent these 2 surfaces from sticking together until overcome by torque, which then results in the pop you hear. Spraying lube on the nut end relies on the oil working it's way along the length of the spline to get where it needs to go.
By the way, the nut takes a 33mm deep socket, which you should be able to get at an auto supply store. I think the same size fits some front wheel drive axle nuts. The correct torque is 118 ft-lbs
Check this...
TEXHAWK0 is correct above, I tried the lazy way the first time around and it came back in a couple days - second time got behind the spindle and no problems since then...
I sprayed just the spline the first time and still had a noise too. It is possible to spray the spline and still not get lube where it needs to be.
You need to make sure you coat the surface of the hub that tightens agains the bearing on the inside. Getting some on the splines will help keep lube in the area, but is not where the noise is coming from. I am not sure how heavy your lubricant is but I used 30wt motor oil and the noise went away. I soaked a Q-Tip in oil and swabbed all the surfaces out to the edge of the bearing. If I have to do it again, I think I would try a high temp. grease to make sure it stays in place.
I would think a u-joint or CV joint would be more of a clunk than a pop. I could definitely tell my noise was coming from the hub and not the driveshaft. I could even make mine click by just rocking the car in gear by hand without the car running. I could put my hand on the hub, and rock the car forward or backward, and when I heard the noise, I could feel it in the hub. I could put my hand on the brake caliper, or the axle shaft, and could not feel it, so I was almost certain it was in the hub somewhere.
R
If the noise went away at all, then at least you know you found the source of the problem.
With the wheel off, when you loosen the axle nut, you can push the axle in enough by hand to expose the surface between the CV joint hub and the bearing. I took a Q-tip, soaked it in motor oil, and swabbed the inside surface of the bearing and the spline. My noise has not returned, but if it does over time, I would consider using a light coating of grease instead of just oil.
