pitted wheels?
Old Aug 15, 2006 | 04:59 PM
thetight's Avatar
thetight
Default pitted wheels?
my 02 coupe has the stock thin spoke polished wheels and it seems there is some pitting going on every wheel why does this happen? is there a way to prevent it. i did a search and came up empty i am sure this has to be talked about often
Old Aug 15, 2006 | 05:13 PM
stormrider's Avatar
stormrider
I am having the same issue especially on the front wheels
Old Aug 15, 2006 | 05:15 PM
thetight's Avatar
thetight
i am sure this is a huge problem why no recall from gm?
Old Aug 15, 2006 | 07:28 PM
louzon's Avatar
louzon
You should see what they look like after 6 salted road winters!
Now they are only used for the winter.
My first set was replaced under warranty after the first winter but to be honset I think it has more to do with the brake dust?
Old Aug 15, 2006 | 09:46 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I noticed by waxing them (zaino) that the pitting does not occur that easy. Plus the brake dust comes right off.
Old Aug 15, 2006 | 11:41 PM
Oldvetter's Avatar
Oldvetter
Change to ceramic brake pads. Wax wheels, once or twice a year. Then use a dedicated "dash california duster" to clean off the dust between car washes.
Old Aug 16, 2006 | 12:50 AM
GrayC5's Avatar
GrayC5
You need to keep a good coat of polish or wax that is clear coat safe on them. You should be able to find a lot of info on proper care of your wheels in the Car Care Discussion section of the Forum. Good luck with the wheels.
Old Aug 16, 2006 | 12:51 AM
vett2002's Avatar
vett2002
7th Gear
Default Gm replaced mine under warranty - new set -same problem
So what convinced them that it was a production problem? My guess, the pattern of the pitts. 2 wheels had pitts around the value stems. The 17" wheels were the worst, all were unacceptable. And, as you can guess the problem is back on the new wheels. I remove the wheels now for clean up and polishing about every 6 months.
Old Aug 16, 2006 | 01:19 AM
Dave68's Avatar
Dave68
The OEM polished wheels have a protective clear coating applied to them. When this coating wears off (abrasion from sand and other hard substances), oxidation occurs. Typical aluminum oxidation creates small pits that may be covered by a gelatonous substrate, especially when exposed to saltwater. Most people (myself included) don't treat their wheels quite as well as they do the body paint, so just as body paint's clearcoat gets worn away over time, so too does the wheel coateing, only at a much faster rate.
Prevention? Wash gently and often with very sudsy water. Follow with Rejex, Zaino, etc.
Old Aug 16, 2006 | 11:04 AM
DPG's Avatar
DPG
St. Jude Donor '06
good wheel maintenance is just as important as paint protection. you should treat them just the same. wheels have a clearcoat on them. You wouldnt leave brake dust and other harmful metal particals on your paint would you? Clean them everytime you clean the car and wax once a year and twice a year if its a year round driver. Oh and spraying on a cleaner and sparying off doesnt cut it, my dad got in trouble doing this and now his wheels are pitting. Remember, you need to apply some sponge or brush to remove the residue from the wheels as you would to any clear coat surface.
Old Aug 16, 2006 | 04:47 PM
thetight's Avatar
thetight
i bought this car 6 weeks ago and already had this problem with the wheels i clean the car every weekend. just wanted to know if this can be removed some how or if there was ever a recall on them
To pitted wheels?
