removing air tubes
Old Aug 16, 2006 | 09:10 PM
blk04z's Avatar
blk04z
Default removing air tubes
I seem to be haveing a hard time removing the air tubes when installing my headers. I feel like im missing something simple. Is it held in behind the manifold my something. Thanks
Old Aug 16, 2006 | 09:25 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Behind the drivers side head there is a nut. I think it was 13mm, tight to get your hand in there to loosen it but it can be done. You don't have to get it all the way out, just loosen it a touch and the bracket should slip off.
Old Aug 16, 2006 | 09:26 PM
ABNVET.I's Avatar
ABNVET.I
Yep loosen it up and it will slip out.
Old Aug 16, 2006 | 09:28 PM
blk04z's Avatar
blk04z
Thanks guys that helps alot.
Old Aug 17, 2006 | 12:48 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Good to know... my Kooks race headers are on their way. No more AIR!!!!
Decided to just go ahead and get new ones so I can get them coated and then install them w/o much downtime on the car.
Will fix the broken ones out of the car and sell.
To removing air tubes
