I Give Up, Tail light LED Question???
1: I don't know which of the three wires on my tail lights I need to hook
into -brown, black or yellow for the driver's side or brown, black or
green for the passenger's side.
2: Another possible cure would be a "led compatible" flasher module, but, I
don't know if a C5 has one or what kind,or where, it would be.
I've tried to find the answers to my own questions,but, I'm having no luck.
Any help you guys could offer would be greatly appreciated.
Thanks, Jason
i know some guys on ebay were selling the halo lights with only 2 flasher modules for all 4 lights and that was causing some guys to have problems.
JDMVETTE,
Yes, my halos have 1 flasher module per light. I put a post in General as well, so I'll try that advice first. Hopefully that fixes the problem. Thank-You for responding. Jason
where did you pick up the extra set of bulb sockets?
I'm sure you could use the old style sockets that took the turn in 1157 bulbs also. They can be picked up from most parts stores. Also worth noting is you only have to put one on each side not two. Once they are zip tied to the existing harness and the light is put back in you'd never know they were there!
I NOW have one resistor on the driver's side and one on the passenger side. Everything works perfectly now. Thanks again to all the members who helped me. You guys ROCK. Jason1: I don't know which of the three wires on my tail lights I need to hook
Thanks, Jason
Just a thought.... Why is fast flashing so bad in the first place???
Fast flashing is simply there to indicate a bulb out.. But LED rarely burn out.. So what if they flash fast?
They still work and flash when the turn signal is on right?
