Headlamp switch
Old Aug 19, 2006 | 05:30 PM
vettman96's Avatar
vettman96
Default Headlamp switch
I need to replace my headlamp switch. It appears that I need to
remove the steering wheel in order to remove the steering
column shroud to access the switch for removal and replacement.
Can anyone provide me the correct procedure to get this done
and have working headlamps again? I would rather do it myself
than take it to the stealership ( or anyone else).
Thank You in advance
Old Aug 19, 2006 | 06:16 PM
dudleyd's Avatar
dudleyd
You do NOT need to pull the airbag/steering wheel but there is one screw on the bottom of the Multifunction switch that is a PITA. Attached is a prity good wright up.
http://forums.corvetteforum.com/show...unction+switch
Old Aug 20, 2006 | 08:49 AM
vettman96's Avatar
vettman96
Thank You Sir. Appreciate the 411
To Headlamp switch
