service column lock/pull key "wait ten seconds"
Old Aug 21, 2006 | 10:10 AM
tweakd's Avatar
tweakd
Default service column lock/pull key "wait ten seconds"
Hey Everyone,
OK, yesterday i went to put the car away and i got the "pull key wait ten seconds" Service column lock on the DIC. I waited and did it a couple of times and it working so i was able to pull it into the garage. My question is can i now install a CLB or do i have to go to the dealer to get the recall? I have tried to read up on it, but i am confused on that part. If you can point me in the right direction it would be great!
Tweakd
Old Aug 21, 2006 | 10:53 AM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
I just installed a clb, from Corvettes of Houston.Had it overnighted and installed it in lesss than 1/2 hr. Very easy to do, plug and play. Use the search function, as there is a very nice write up that I used by phil97.com
Old Aug 21, 2006 | 11:14 AM
JC in XTC5's Avatar
JC in XTC5
Originally Posted by tweakd
Hey Everyone,
Tweakd
As long as the wheel is unlocked you can and should install the CLB.
As long as you haven't had one specific recall (the one issued a few years ago that reprogrammed the PCM and modified the CL relay circuit) you can install the CLB.
Old Aug 21, 2006 | 11:27 AM
tweakd's Avatar
tweakd
Thanks Guys!!! I am going to order it right now!
To service column lock/pull key "wait ten seconds"
