I believe both MAFS are 75mm. '01 and later are 85mm...pretty sure
This is true, and, in addition, the IAT sensor was moved to the MAF in 2001. As a side note, LS1 Camaro or LS1 Firebird, MAFs will work in a Corvette, again size (generation) dependent.
Ed
