Do I need an oil cooler?
Old Aug 22, 2006 | 09:47 AM
rd122481's Avatar
rd122481
Default Do I need an oil cooler?
Do I need an oil cooler? My oil temp got up to 221 degrees today while I was driving hard for about 2-3 minutes. Isn't that just about where the fluid just starts to break down? Or maybe the breakdown temp is higher being as I'm using Mobil 1 synthetic.
Old Aug 22, 2006 | 10:27 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
No, you do not need an oil cooler. That is the normal.
Old Aug 22, 2006 | 10:34 AM
StArrow68's Avatar
StArrow68
For comparison, those of us that drive on road courses, sustained rev's for 20+ minutes of a session get oil temps that approach 300 degrees and I got my oil cooler when I started to see 290's. Now with the cooler I get into the 270's anyway. Some with integrated oil coolers see lower numbers than that.
On the other hand, with a 175 thermostat unless the outside temps get over 60 degrees I don't get up to 180 unless I make an effort to keep it in a lower gear for a bit.
Randy
Old Aug 22, 2006 | 04:56 PM
MattB's Avatar
MattB
Do some searches, there are a few threads about oil temps. 300 is pretty normal for road racing, and from what remember mobil-1 doesn't start having problems till around 350?
Old Aug 22, 2006 | 05:17 PM
AU N EGL's Avatar
AU N EGL
Yes and NO. 250-255 consistant oil temp is when Oil coolers are recomended. Yes the oil can take high temps of 300-350 but the internal engine parts can not.
So the magic number we use on the track is 250*. Plus when you run those sustained temps a thicker viscosisty oil is a good idea as well.
I use M1 15-W50, have an oil cooler and 3qt accusump. Change my oil very two weekends on the track or about every 500 miles.
Oil annalyses says that is just about right
Old Aug 22, 2006 | 07:17 PM
MUKAK's Avatar
MUKAK
I have a stand alone Eng Oil cooler and my temp are from 250-260 on the road coarse...
I remember b4 the cooler my temp were around 290-300 300* and your engines life get cut in half...
Old Aug 22, 2006 | 09:33 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Blackstone told me go 2500 miles when they tested the oil
Old Aug 22, 2006 | 10:35 PM
J.R.'s Avatar
J.R.
Default Oil cooler
It's a must if you track the car.
240-250 oil temp with a cooler (either integrated or seperate) for a 30 min session.
Integrated - Ron Davis is great
External - DRM makes a nice setup
Mobil 1 15/50 for track days
Old Aug 22, 2006 | 11:44 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You should be okay where it is at! Take the dough and spend it on another performance part if desired! My two cents!
Thanks,Matt
To Do I need an oil cooler?
