alternator bracket swap
Old Aug 22, 2006 | 11:04 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
Default alternator bracket swap
any special tools needed to swap out an alternator bracket on the front of an 04?
does the power steering pump just bolt to it or do you have to take the pulley off to do the swap?
thanks
Old Aug 22, 2006 | 11:21 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
TTT, My understanding is you have to remove the pulley to get the pump out of the bracket. Can anybody else confirm this?
Chris
Old Aug 22, 2006 | 03:45 PM
Stangkiller
ttt
Old Aug 22, 2006 | 05:02 PM
97Rob's Avatar
97Rob
Willyfast just removed mine to polish it, and the power steering pump had to come off.
Old Aug 22, 2006 | 05:32 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Chris
Been a while since I've done it myself, but yes, I think you do have to remove the pulley to get the pump off. Just use a pulley puller from almost any auto parts store and you'll be OK.
Old Aug 22, 2006 | 05:45 PM
SynistrC5's Avatar
SynistrC5
The problem with the factory pulley is that it is solid and that it is nearly impossible to access the retaining bolts. I went with a spoked aftermarket model like this one
http://www.zip-products.com/Corvette...EFA9EB63AE41FC
this made it alot easier I have had the front dress of mycar torn down 4 or 5 times and this made my life alot easier not to metion everytime I try to take a factory pulley off it breaks
Old Aug 22, 2006 | 06:52 PM
Phil97SVT's Avatar
Phil97SVT
I just purchased one of your pulleys for my corvette, had the pulley break midway through 3rd gear and cut the PS line hitting the slicks with power steering fluid. Can I tell you it wasn't a fun ride.
Old Aug 22, 2006 | 08:57 PM
willyfastz's Avatar
willyfastz
Yes you have to pull the pulley off the pump to get it off the alternator bracket. There's a special tool to remove the pulley from the pump.
And Rob your bracket looks good now, it's SHINNY.
Old Aug 22, 2006 | 11:09 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
You can remove the pulley/pump as one assembly. I did not use a special puller to swap in my chrome bracket. You can get to the bolts, they are a pain, but you can get to them.
Old Aug 22, 2006 | 11:16 PM
97Rob's Avatar
97Rob
You da man!
Old Aug 22, 2006 | 11:23 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You can do it! Just be patient and take your time and don't tilt too many back wait till after!
Thanks,Matt
Old Aug 23, 2006 | 09:31 AM
willyfastz's Avatar
willyfastz
You might can do it that way, but I sure wouldn't want to.
Old Aug 23, 2006 | 09:36 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
i ordered one of them pulleys....mainly because it was very bling. but mainly so i can get a puller and if it breaks i have one to go back on.
maybe tomorrow then me and the stangkiller might be turning a few wrenches in the bee hive....
Old Aug 23, 2006 | 11:03 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
^ Sweet I get to see your car I'll be calling you guys Friday night.
Old Aug 23, 2006 | 11:49 AM
WKMCD's Avatar
WKMCD
Can you say "Pimp my ride".
BTW: I want one!
Old Aug 23, 2006 | 12:21 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
BTW: I want one!
i would have liked it better if it was black.
black is the new chrome....
wont get to do the install this week, alternator wont be here till monday or tuesday from being powdercoated black....but the black bracket, EWP, and katech tensioner look pimp as hell sittin on my bench in the garage!
Old Aug 23, 2006 | 12:23 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
very good chance friday night we will be at legends sports bar at the holiday inn where were staying.... imma gonna have ta sho chris how we drink up here!
Old Aug 23, 2006 | 01:03 PM
SynistrC5's Avatar
SynistrC5
legends sports bar is a damn good time!
Old Oct 22, 2006 | 11:30 PM
Cscokd's Avatar
Cscokd
I recently bought one of these pulleys and tried to install it today. Unfortunately the inside tolerances of the shaft hole is too tight and shaved some of the aluminum material until the install tool eventually broke. Of course I couldn't see what was actually happening until I removed the install tool then it all became clear. At this point my new $187.00 pump and $100 pulley are NFG unless you have some way to remove it. Right now I'm out a bunch of money not including tool rental cost and replacement of the broken tool parts. I'm going to call Synister tomorrow and see if anything can possibly be done about this.
John
To alternator bracket swap
