active handling please help
Old Aug 23, 2006 | 01:34 AM
twoduners11's Avatar
twoduners11
Default active handling please help
hi all, new to this stuff so bear w/ me. ive done a search and couldnt find a problem simmilar to mine. just bought the car a couple weeks ago (98 coupe) the active handeling used to come on and off at will. sometimes constantly! when it was on i could use the button to turn it off. when it was off i could use the button to turn it on it just wouldnt stay there for long. now the button doesnt do anything, but the good news is it quit switching itself back and forth. but it is stuck on. any help is greatly appreciated.
mark
Old Aug 23, 2006 | 01:45 AM
RedRider98's Avatar
RedRider98
mark
I believe you are referring to Traction Control, not Active Handling.
Old Aug 23, 2006 | 01:58 AM
twoduners11
the little button says "active handling" and the id tag states jl4 ive read that means it has active handling?
Old Aug 23, 2006 | 08:23 AM
RedRider98's Avatar
RedRider98
JL4 is Active Handling, I guess I was wrong. I didn't know Active Handling had an on/off button. Sorry!
Old Aug 23, 2006 | 08:55 AM
Busa196's Avatar
Busa196
If you press the button and hold it down for about 3-4 seconds you'll put the car in "Competition Mode".......this means that your Traction Control is off, but your Active Handling remains on. To undo, simply press and hold the button again and the car should return to both systems being "on"
If I read your post correctly it sounds like the system is changing by itself while the car is running? If so, that's a whole nother issue. However, it doesn't matter what mode you have the car in but once you turn the car off and then re-start it and will always default back to T/C on and Active Handling on. You would have to manually press the button to change the setting after each start up to turn either system off. Not sure if this helps?
-Busa196-
Old Aug 23, 2006 | 09:16 AM
keanucosmo's Avatar
keanucosmo
-Busa196-
On 98's you have to be stopped to do this.
Old Aug 23, 2006 | 11:49 PM
twoduners11
maybe i wasnt clear? the active handling used to have a mind of its own. now i cant get it to turn off. the button does nothing! anyone know which wires to cross to see if its just the switch thats bad? or any suggestions
thx mark
Old Aug 24, 2006 | 01:25 AM
ckd's Avatar
ckd
Have you tried pulling up the trim and checking the wires, it's easy to pop the trim out.
Old Aug 24, 2006 | 01:54 AM
twoduners11
yes sir that connection is fine. so im driving down the freeway tonight and all the sudden "tract/active handling off" i must have pushed that button 100 times after that and it changed from on to off just as it should (did it driving 30 mph 70mph and stopped) its been said that the vehicle must be stopped to turn active handling off? i dont even know if its still broke or not
Old Aug 24, 2006 | 10:03 PM
twoduners11
ok now its doing whatever it wants to (and it sure doesnt seem to know what it wants to do, changes back and forth 10-20 times per minute)
is anyone out there?
Old Aug 24, 2006 | 10:57 PM
ScreaminDemon's Avatar
ScreaminDemon
I'm interested in this too! I can't turn it off after my engine swap, the traction (on) and active handling (on) warning lights just stay on! I can't do a burnout from a dead stop!!!!! The pcm just retards my timing!!!! I can't seem to find a wire or plug that I have left undone or damaged!
Old Aug 25, 2006 | 12:32 AM
Bill Dearborn's Avatar
Bill Dearborn
Do you have any codes showing on the DIC when you run the On Board Diagnostic system? From the schematic it looks like the button feeds the BCM. The button is a momentary switch to ground of an input to the BCM at D15 C2. Once your finger leaves the button the switch is open. When the switch is open the input line is pulled to 12 Volts through a resistor in the BCM. You should be able to see this 12 volts on the Brn/Wht wire connected to the switch. When you push the switch it should go to zero.
Bill
Old Aug 25, 2006 | 01:52 AM
David's99Vette's Avatar
David's99Vette
1st Gear
Default Active Handling
I just bought my 99 Vette yesterday! It gets delivered Monday. I was told that the Active handling issue was a common problem on the C5. The display continually shows Active Handling Warming… it doesn't even turn on. The previous owner said there was a common ground problem. His explanation was that if I find the common ground it will fix most of the problems, including the Passenger window issue.
I’m looking for help also!
Old Aug 25, 2006 | 04:01 PM
jwg2's Avatar
jwg2
had a similar problem in mine, thread here http://forums.corvetteforum.com/show....php?t=1092720
I'd be driving down the highway in a straight line, AH would come on and off, with right or left brakes deploying. very scary to have your car tug right or left at highway speeds. took 6 trips to the dealer, turned out to be the steering wheel position sensor, but never threw a code. I just had the luck of finding a tech who had seen the gremlin before
Old Aug 27, 2006 | 12:45 AM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
The car does not have to be stopped to turn active handling/ traction control off or on. It only has to be stopped to put it in "competitive driving" mode (Holding button down for 5+ seconds and dash will say competitive driving.) which turns off the traction control but leaves the active handling on. This is only on the '97-'00 cars, '01 and newer have upgraded electronics and will work on the fly.
Old Aug 27, 2006 | 02:20 PM
DeeGee's Avatar
DeeGee
You may want to read this thread and see if you recognise the symptoms
http://forums.corvetteforum.com/show...highlight=ebcm
Old Aug 29, 2006 | 02:10 AM
twoduners11
Bill
all the codes
10 pcm p0650h
40 bcm b2597h
a1 rdcm u1255h
u1064h
u1016h
u1096h
bo rfa u1096h
u1064h
u1016h
c2115hc
the only current code is the c2115hc (i need to replace the left rear tire sensor)
To active handling please help
Old Aug 29, 2006 | 08:33 AM
Gordy M's Avatar
Gordy M
Since you are not throwing the C1283, steering wheel sensor, your problem is the ground. On the 1997-98 models, there is a left rear ground by the exhaust that is very sensitive and some others near the engine. Search for grounds and there is a diagram of all the grounds in the c5 and several topics on locating and cleaning them...most of the issues with electronics not working right are associated with bad grounds.
Old Aug 29, 2006 | 09:02 AM
dwarmenzerk's Avatar
dwarmenzerk
im interested in this as well. I have a 99 coupe, luckily i dont have any problems with the TC or AH coming on during regular driving, but i cannot get the darn thing into competition driving..? ive tried holding the sucker down just not sure what is going on..!
Old Sep 6, 2006 | 10:21 PM
ScreaminDemon
Anything new here?
