Clunk noise when turning left
Old Aug 24, 2006 | 02:02 PM
bomax's Avatar
bomax
Default Clunk noise when turning left
My 2004 Z has a loud clunk clunk clunk clunk noise whenever I make a left turn and medium or low speeds. It seems to be getting worse.
What should I check for?
I'm under warranty but taking it to the dealer is a last resort option!
Old Aug 24, 2006 | 02:37 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
sounds like diff chatter. (only occurs during turns) you may need diff fluid or more friction modifier additive.
I swapped mine to Amsoil Severe Gear 75w-90 and didnt need the additive. (has it mixed in already)
Old Aug 24, 2006 | 03:26 PM
bomax's Avatar
bomax
Is there any way to verify this short of replacing the fluid?
Old Aug 24, 2006 | 04:10 PM
willyfastz's Avatar
willyfastz
Is the sound coming from the front or rear, can you tell?
Old Aug 24, 2006 | 04:17 PM
bomax's Avatar
bomax
Hard to tell... but it does sound like the rear.
Old Aug 24, 2006 | 04:27 PM
willyfastz's Avatar
willyfastz
If so to check the fluid in the dif. look at the rear of it and you'll see a allen head plug on the right side about middle way up from the bottom of it. Screw it out and the fluid level should be level with that plug.
Old Aug 24, 2006 | 04:31 PM
bomax's Avatar
bomax
I went ahead and ordered some of the recommended Amsoil, as well as some amsoil ATF for the tranny (it is kinda notchy). Does the rear diff have a drain plug like the tranny or do I need to remove the cover?
Old Aug 24, 2006 | 10:04 PM
FASST LN's Avatar
FASST LN
The differential has a drain plug that faces the asphalt (faces straight down) and requires the same size allen wrench as the fill plug. Excellent for draining. Just did mine today.
To Clunk noise when turning left
