Long Tube headers vs Shortie headers
Old Aug 25, 2006 | 01:10 AM
Silver Z06 Driver's Avatar
Silver Z06 Driver
Default Long Tube headers vs Shortie headers
Does anyone have any dyno results for LT vs Shorties.... Are LT's a BIG difference or just marginal over Shorties?????
Old Aug 25, 2006 | 12:57 PM
HRDTOPC54FUN's Avatar
HRDTOPC54FUN
Shorties are marginal over the stock manifolds, prbly not wirth the effort for most unless you live in Cali and want to stay legal.
Old Aug 25, 2006 | 01:41 PM
bomax's Avatar
bomax
Don't bother with the shorties...
Old Aug 25, 2006 | 02:35 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
B&B shorties are worth 10 rwhp. There was a thread a member had that supported this. I've had the shorties and although I can't support 10 with dyno proof, I believe it. Gotta be B&B's though............
Old Aug 25, 2006 | 03:10 PM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
Cheap shorties are marginal. The B&B have EQUAL LENGTH PRIMARIES!!! Not to mention top notch collecters and welds. And yes, they are worth about 10 to the wheels. This is without adding an x-pipe or cats, like the long-tube systems, which typically gain 25ish tothe wheels. My car with the B&B shorties and Bullets sounds better than a long-tube car with mufflers. No burnt wire worries, stock cats, all smog legal if I ever leave Florida, $950 invested total. (picked up the shorties for $450 off ebay)
Old Aug 25, 2006 | 03:39 PM
Charley Hoyt's Avatar
Charley Hoyt
My opinion (Backed up with Dyno data) is that Short tube headers are a waste of money. Click on the link to my website...and they click on Dyno Days. Look At Ted C's Z06 dyno results for Dyno day one and then look at his results (CrazyTed) for Dynoday #2. By adding Short tube headers and a polished throttle body he gained 1.5 HP....Which is within the error margin for the Dyno.
I Don't mean to hurt anyones feelings....But, The data tells the story.
Sorry,
Old Aug 25, 2006 | 03:55 PM
byte_me's Avatar
byte_me
I had shorties (B&B) on my 97 before I finally switched to LT (Kooks to be exact) The guy I bought them had them on his track car and showed me the dyno of 12RWHP from these alone. So I am not sure where the 1.5 comes in above...though if it was a Z06- I understand that stock Z06 manifolds flow better then the early model (97-99) manifolds do. I can tell you that the car (with the shorties) was louder and I could feel the increase mostly in the upper RPM range. I later added the LS6 intake and noticed a larger increase with the combo...
The long tubes- well lets face it, this is the way to go if you want the most from the exhaust...I had high flow cats and the x-pipe installed and this was a very noticable increase over the shorties...
here is the kicker- shorties cost $300 and long tubes were $1000 (both used) this does not inclued installation...
Shorties are good for the person needing to be legal in emission States - Long tubes are not...
There are a lot of guys running shorties and love them...but the ultimate step would be LT's if you can...
Shorties are not garbage, just not the most gainful solution...
Old Aug 25, 2006 | 05:00 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Old Aug 25, 2006 | 06:22 PM
tiojames's Avatar
tiojames
Default headers
Don't buy into the story that LTs cost $1000 or more. You can now get a set of Jet-Hot nickel ceramic coated LT headers for less than $650 shipped. I have a set on my vert and when it was tuned with the H/C pkg. the tuner said he couldn't see a significant difference in hp with the other long tubes. The only reason to use shorties is to pass smog tests.
Old Aug 25, 2006 | 06:33 PM
Scoundrl's Avatar
Scoundrl
FWIW I have shortie on my 2000 with stock head, ls1 intake stock TB, ud pulley Stingers and vararam and an LG G5x3 cam and made 390 to the wheels on a mustang dyno. I am sure the shorties helped out and make the perfect sound w/out getting to loud. I make just ove 90db at the track.
Old Aug 25, 2006 | 07:13 PM
MotleyDrew's Avatar
MotleyDrew
If you have a blower or Forced induction setup there probably isn't much differnece between a long tube header and shorty.
If I was to run N/A then long tubes are the way to go.
Old Aug 25, 2006 | 08:05 PM
Charley Hoyt
Originally Posted by Scoundrl
FWIW I have shortie on my 2000 with stock head, ls1 intake stock TB, ud pulley Stingers and vararam and made 390 to the wheels on a mustang dyno. I am sure the shorties helped out and make the perfect sound w/out getting to loud. I make just ove 90db at the track.
WOW Your car must be a freak of nature (and I mean that in a good way). I hosted four dynodays with 100's of corvettes...and no one ever made anywhere near those numbers with out significant modifications (Cam, heads, etc). I wish my car put out numbers like that!
Old Aug 25, 2006 | 08:11 PM
Tigershark3's Avatar
Tigershark3
Old Aug 25, 2006 | 08:40 PM
Z28TOZO6's Avatar
Z28TOZO6
Where did you get them from?
Old Aug 25, 2006 | 08:41 PM
Z28TOZO6's Avatar
Z28TOZO6
Better off leaving the stock manifolds and putting a cam in?
Old Aug 25, 2006 | 09:06 PM
SSBob's Avatar
SSBob
My FRC has an ancient (circa 2000) MTI head/cam package, Granatelli mass air, and LS6 intake. When I bought the car it had 1 3/4" B & B shorties, Bassani x-pipe, and B & B Route 66 mufflers. It came with dyno sheets from MTI showing 402 rwhp and 375 lbs.-ft.
I recently switched out the headers and x-pipe to a set of 1 3/4" American Racing long-tubes with one of their 3" x-pipes with high-flow cats. After a conservative tune by Corey at Henderson Performance and with no other mods, the car made 421 rwhp and 398 lbs.-ft.
Different dynos, obviously, but both are the same model Superflow, and both runs were corrected for altitude, temperature, barometric pressure, and dew point.
The American Racing headers are of tremendous quality, by the way--all stainless, merge collectors, nice welds, etc. The two guys who founded ARH are former Kooks employees. At $1450 shipped the setup was not cheap, but since my car came with the B & B/Bassani stuff I'll be able to recoup some of that by selling the take-off parts. I guess it comes down to deciding if that kind of money is worth about 20 hp/20 lbs.-ft. over a comparable shorty setup.
I don't really notice any difference in sound, BTW, but I've been around a lot of open exhausts in my life so I may not be the best person to ask about that.
Old Aug 25, 2006 | 10:34 PM
_Will_'s Avatar
_Will_
Stainless steel do. Jet-Hot are made of low grade mild steel tubing.
Probably not much of a difference on a mild-setup, but I know a guy with a 402 ls2 that gained 12rwhp by switching from dynatech to LG pro headers.
Vette magazine dyno tested my combo, b&b shorties and bullets with stock h-pipe/cats, and picked up 30rwhp w/out tuning. I believe these results, because I've test driven a car with long-tubes, random tech cats, x-pipe, and aftermarket exhaust that actually had mufflers(corsa) and it was not as loud and did not have as much pep as my car. Only difference was intake, I have a vortex and the car i drove had a blackwing w/ ice box. Of course unlike my shorties, I believe the long-tubes on this car did not have equal length primaries. They were the cheap ceramic coated kind and not LG.
To Long Tube headers vs Shortie headers
Old Aug 25, 2006 | 10:43 PM
tiojames's Avatar
tiojames
Default Headers
Sent you a PM with all the info.
Old Aug 25, 2006 | 10:52 PM
tiojames's Avatar
tiojames
Default headers
Vette magazine dyno tested my combo, b&b shorties and bullets with stock h-pipe/cats, and picked up 30rwhp w/out tuning. I believe these results, because I've test driven a car with long-tubes, random tech cats, x-pipe, and aftermarket exhaust that actually had mufflers(corsa) and it was not as loud and did not have as much pep as my car. Only difference was intake, I have a vortex and the car i drove had a blackwing w/ ice box. Of course unlike my shorties, I believe the long-tubes on this car did not have equal length primaries. They were the cheap ceramic coated kind and not LG.[/QUOTE]
Jet-Hots headers are equal lenght 1 3/4s tubing into 3" collectors. Unlike ss which burnishes itself and looks rusty in a short time the coated headers retain there sheen, put less heat in the engine compartment. Also mild steel does not expand and contract nearly as much as ss does and will not crack as some of the ss headers have.
Old Aug 26, 2006 | 01:26 AM
D C's Avatar
D C
USMC (retired)
I never had shorties, but with the above. ARH is an awesome product. Along with GHL and tune I made significant improvements from baseline. Check out sig.
