Oil Temp Sensor
Old Aug 26, 2006 | 03:20 PM
Varmit's Avatar
Varmit
St. Jude Donor '08
Default Oil Temp Sensor
Any one have the p/n to the oil temp sensor located next to the oil filter on a 99 FRC?? I keep getting temp readings 30-40 degrees below engine temps, or low oil temp in the DIC.
Old Aug 26, 2006 | 06:08 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Old Aug 26, 2006 | 06:21 PM
Varmit's Avatar
Varmit
St. Jude Donor '08
Originally Posted by screw991le
15369305
Rich
Thanks a lot. Will go down to Chevy dealership tomorrow and try to get one.
Benny
Old Aug 26, 2006 | 06:55 PM
screw991le's Avatar
screw991le
Originally Posted by RamonaC5
Rich
Benny
Try like a NAPA also, they are cheaper for the generics.
Old Aug 26, 2006 | 07:00 PM
Varmit's Avatar
Varmit
St. Jude Donor '08
Will do
Old Aug 31, 2006 | 07:24 PM
2000RedFRC's Avatar
2000RedFRC
is this specific to a 99 or is this also compliant with an 01? Also, when taking out the old sensor, i guess i should expect some oil to leak out? is this going to be a lot or just a little bit? THANKS!
Old Aug 31, 2006 | 09:08 PM
Varmit's Avatar
Varmit
St. Jude Donor '08
I wish I could tell you. Went to NAPA they gave me what they thought was the right sensor, raised the car...wrong sensor. Went to the dealership, said there were two in So Cal, both in L.A. said it would be in the next day. I forgot to ask him the next day of what month. Still waiting on the sensor!!
If the engine is cold I don't think there will be much of a leak, hopefully not. Not only am I getting a low temp, I'm also getting a low oil level. Checks fine, but I think the same sensor handles both issues.
Old Sep 1, 2006 | 07:54 AM
CARRJET's Avatar
CARRJET
The oil level sensor is on the bottom RH side of the oil pan, and as you already know the temp is in the oil filter side
Old Sep 1, 2006 | 09:01 AM
Varmit's Avatar
Varmit
St. Jude Donor '08
Thanks. This will be the third different sensor thats gone bad in the last 1500 miles. Never had any issues with them before. Car only has 36k on it. Engine only has 1500 miles on it.
To Oil Temp Sensor
