Worn AC idler Pully
Old Aug 27, 2006 | 09:09 AM
5.0 RACER's Avatar
5.0 RACER
Default Worn AC idler Pully
I've been replacing the various belts and such on the 99 FRC and came across this worn pulley. the vehicle has 104K on it. This is the AC idler pulley.
Old Aug 27, 2006 | 10:27 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Mine was worn at 50,000 miles.
Old Aug 28, 2006 | 07:32 AM
ryoder's Avatar
ryoder
How can you tell if the idler pulley is bad?
Old Aug 28, 2006 | 08:43 PM
5.0 RACER's Avatar
5.0 RACER
until I removed it, all I knew it had some noise up front, and since I had owned it for only 2 months, I thought I would go through things.
Replaced the main idler pully, serpentine belt, accessory belt, idler for the ac.
Its quieter now. That pulley was noisy and the bearing was sloppy.
To Worn AC idler Pully
