01 Z06 click noise reverse to forward
Old Aug 28, 2006 | 10:38 AM
dmkhnr's Avatar
dmkhnr
8th Gear
Default 01 Z06 click noise reverse to forward
I'm experiencing a click noise when I drive from reverse to forward. For instance:
Backing out of a parking space, put it in first, and upon forward movement I get a click, like something is loose in the rear. Everything else seems fine, and I don't get it on any of the other shifts.
What should I look for? I have a warranty, but its not through GM, so I'd like to know exactly what I'm up against before I take it in.
thanks,
Old Aug 28, 2006 | 11:13 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
It's a loose axle nut, very common, do a search, you'll find what you need. Basically, back the nut off on each side, spray some lube into the splines, re-tighten the nut to the proper spec.
Old Aug 31, 2006 | 10:57 AM
dmkhnr's Avatar
dmkhnr
8th Gear
That fixed it!!!
thank you,
To 01 Z06 click noise reverse to forward
