Help!!! Telescopic Steering Wheel problems
Old Aug 29, 2006 | 01:04 AM
aus10cop's Avatar
aus10cop
Default Help!!! Telescopic Steering Wheel problems
My telescopic steering wheel just quit working the other day. I've looked in the owners manual, hoping to find some info about a fuse or something, but all I could find was some really vague info. Any ideas?
Old Aug 29, 2006 | 01:58 AM
2KVetteMan's Avatar
2KVetteMan
Do a search. I know there is a trick to getting it to work again. Something like tap the level forward six times to engage it again.
If not I have the part number to the steering telescope that needs replacing.
PM if you need it. I can fax it over if you like.
Cheers!!
Old Aug 29, 2006 | 02:25 AM
94legaleagle's Avatar
94legaleagle
IF you have to replace the actuator or the motor, let me know first. I've got both parts left over after my rebuilding a 2001 and I've also got an extra telescopic switch(don't ask why I have extras).
I'm guessing my 2001 parts are the same as your 2004 parts (we'd check part numbers), and I can save you a TON of $$$ over what the stealership is gonna want for those parts -
Hopefully, you have a simple fix. If not, or if you need help diagnosing your problem or swapping parts WITHOUT removing the entire steering column (as recommended by the book), PM me and I'll be glad to help.
Old Aug 29, 2006 | 02:29 AM
aus10cop's Avatar
aus10cop
Default Problem Is Fixed, Thanks To You Guys
I conducted a search as you suggested, and learned more about the "trick" of pushing the lever forward 7 times. My problem was immediately solved. I can't thank you guys enough for helping me out.
Old Aug 29, 2006 | 11:54 AM
RedY2K's Avatar
RedY2K
Hey, Officer (it pays to be polite to cops ), did you search this forum? I tried various searches and couldn't find the telescopic wheel trick. Would appreciate some clarification on pushing the lever seven times.
Thanks.
Old Aug 29, 2006 | 02:26 PM
aus10cop's Avatar
aus10cop
Thanks.
This is where I found it last night. Tried it, and it worked.
http://forums.corvetteforum.com/show...ght=telescopic
The only thing I could find was on the 2nd post of this thread.
Old Aug 30, 2006 | 04:27 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I believe that basically sets your soft stops back to that actual hard stops. You can do it for your seats as well.
Tim
99 Coupe
To Help!!! Telescopic Steering Wheel problems
