Some relay help please!
Old Aug 29, 2006 | 07:30 AM
Sethmo99's Avatar
Sethmo99
Default Some relay help please!
I currently tracked down my CLB issue to a faulty relay and bypass plug, but now my AC doesn't work! I read that one of the three relays above the BCM was the AC blower motor? Is this true, and if so will I risk my column fouling up again if I start changing relays to test it? Please add some technical insight because the last thing I want to do is go throught he whole column lock issue again.
