2000 headlight motor
Old Aug 30, 2006 | 02:05 PM
ken Palm's Avatar
ken Palm
1st Gear
Default 2000 headlight motor
Does anyone know what causes the headlight motor to keep running after the lights are turned off? They will continue to work for a few times then they will not open. If I open them with the manual override they will start working again, but will stop have a few times.
Old Aug 30, 2006 | 02:10 PM
VetteDrmr's Avatar
VetteDrmr
Sounds like the internal gear is stripped. You can try pulling the arm off the motor, turning it through 180 degrees, then put the arm back on. Or you can replace the gear. I believe the Tech Tips section shows how to replace the gear.
HTH, and have a good one,
Mike
Old Aug 30, 2006 | 02:48 PM
kvozel's Avatar
kvozel
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
It's the gear.
Get a brass one here
Select Electrical, then scroll down to the Corvette section.
To 2000 headlight motor
