NEED HELP: Vert Top Install
Old Aug 31, 2006 | 10:33 AM
RWVH's Avatar
RWVH
Default NEED HELP: Vert Top Install
Going to try and install new top on my 2000 convertible . Has anyone done this ?? Need tips and instructions if you have them.
Old Sep 1, 2006 | 05:37 PM
RWVH's Avatar
RWVH
Ttt
Old Sep 1, 2006 | 10:15 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I'm surprised there isn't a good how-to on this, I'll try to find a vert this fall/winter to replace
Old Sep 2, 2006 | 01:21 AM
RWVH's Avatar
RWVH
Me too, can't believe some one hasn't tried this. If your looking for one come on down to OK.
Old Sep 2, 2006 | 04:49 PM
BloodRayne's Avatar
BloodRayne
I just did mine 2 weeks ago..its not that hard..you must undo the seatbelt bolt underneath the plastic covering. also a screw or bolt for the plastic covering by the seatbelt covering...I took my waterfall off but i dont think ya have to..its only 6 screws i think..Once you get all the plastic off and you can see the bolts that hold in the top...I think there are six..very easy to get too. the top slides out towards the front..Also when removing origional top i had the top opened and folded up(helps to have a holder) I makes removing bolts easier...once you get it out..reverse process however do not tighten the new top completely in..just snug each bolt almost by hand tightning them. close top and latch down...then tightn bolts snugly with socket..then open up top and crank them down to spec..I did not have a torque wrench but you want it pretty tight i think. I did the swap with a buddy of mine in about 45 min.
Old Sep 2, 2006 | 07:20 PM
TNT Vette's Avatar
TNT Vette
Default Clarification please!
I have posted a similar thread in this forum a number of times in the last six months or so and am very interested in hearing from someone that has replaced a C5 top on their own.
For clarification, are you talking about the removal of your entire top, including the hinges, weatherstripping, headliner, etc. (as opposed to just the cloth top overlay)?
I would both benefit greatly and be very gracious for someone's input on replacing just the fabric top.
Old Sep 3, 2006 | 05:31 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Sounds like BloodRayne replaced his whole assembly, frame and all! I too, am looking for instuctions on replacing the cloth top only.
Old Sep 3, 2006 | 08:29 PM
BloodRayne's Avatar
BloodRayne
yes, I did the whole assembly and all...it was VERY easy...no down time for an installer to have my car several days...I wouldnt even know where to start to just replace the cloth.....
BloodRayne's Avatar
BloodRayne
yes, I did the whole assembly and all...it was VERY easy...no down time for an installer to have my car several days...I wouldnt even know where to start to just replace the cloth.....sory for double post
Old Sep 3, 2006 | 10:30 PM
JD's C5's Avatar
JD's C5
I tryed to replace mine and it was a nightmare. Finally, I just took it to a local guy who replaces convertible tops and does interior work. He does vettes all the time and it still took he and an assistant about 3 hours to do it. He charge me $250 and I am happy about the deal. He said he has to fix quite a few that people try to do on their own.
To NEED HELP: Vert Top Install
