Electrical problems
Old Sep 1, 2006 | 10:00 PM
02vert333's Avatar
02vert333
Default Electrical problems
I Am A New Member . How Is Everybody Doing ? I Need Some Help . I Have A 2002 Corvette Conv 6spd That Wont Run . I Keep Blowing The Throthle Control Fuse In The Fuse Box Under The Hood . I Took It To The Dealer And They Said That They Fixed It But They Didnt . I Was Able To Replace The Fuse Before And The Car Would Run But Not Now .all That Happens Is The Fuse Blows Reduce Engine Speed Service Traction Control Light On Dash . I Dont Know What Else To Do Or Who To Take It Too.
Does Anyone Else Have A Simillar Problem ? Does Anybody Know A Good Vert Mechanic In Ma? Please Help
Old Sep 1, 2006 | 10:03 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I'm in South Windsor CT, start by ck'ing the wire harness near the rear of the intake, there have been a few cars that have chaffed in the area of the firewall/fuel rail plate
http://forums.corvetteforum.com/show...7&postcount=18
ck the pics out
Old Sep 1, 2006 | 10:24 PM
02vert333's Avatar
02vert333
I Did Look At Those Wires Today But I Did Not Go That Far Back . I'll Try That In The Morning To See If They Are Chafed Thanks For The Pics . Really Helpfull Hope It Is Something Simple Like That. Does Sound Like A Fix Because Sometimes I Wiggle That Harness And The Car Runs . But Other Times I Wiggle The Wires And Nothing .
Old Sep 1, 2006 | 11:01 PM
02vert333's Avatar
02vert333
Does Anyone Else Have Any Ideas
Old Sep 1, 2006 | 11:57 PM
SteveDoten's Avatar
SteveDoten
codes?
Old Sep 2, 2006 | 12:05 AM
vetracn98's Avatar
vetracn98
St. Jude Donor '08
What kind of codes are you getting? Do you know how to look those up? How do you manage to capitalize every word in a sentence? I have troubles remember to do the first most of the times. no i am not being rude i was honestly asking.
Old Sep 2, 2006 | 05:01 AM
BlownFRC's Avatar
BlownFRC
Contact Bill Curlee here on the forum, he is the electrical guru and might be able to help you. Good luck!
Old Sep 2, 2006 | 08:01 AM
02vert333's Avatar
02vert333
Ill Try Pulling The Codes Today Too See What They Are
Old Sep 2, 2006 | 10:10 AM
02vert333's Avatar
02vert333
I Looked At The Wiring Harness Today And The Wires Were Chafed . So I Fix It And Took It For A Ride And The Reduce Engine Speed Came On . I Turned The Car Off And Than Turned It Back On And It Fine But Check Engine Light Is On .thanks For Your Help Conneticut.
To Electrical problems
