How to remove the instrument cluster
Old Sep 3, 2006 | 07:18 PM
Phil97SVT's Avatar
Phil97SVT
Default How to remove the instrument cluster
Are there any tutorials or tips?
Old Sep 3, 2006 | 07:23 PM
Mike Mercury's Avatar
Mike Mercury
http://thelapd.com/bezel.htm
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
www.vetteessentials.com
i think there is a 'how to' for the bezels; be careful with the hud connection up top
Old Sep 3, 2006 | 07:53 PM
WKMCD's Avatar
WKMCD
"Pace This" has some good instructions around here somewhere. I assume this is for a HUD install? If you are just swapping out the cluster you can to it by dropping the sterring column to make room.
Old Sep 3, 2006 | 08:04 PM
99blackFRC's Avatar
99blackFRC
I've done a few of these installs.. PM me if you have any specific questions.
Old Sep 3, 2006 | 10:28 PM
Mike Mercury
His method is from the top - removing the dashboard cover. I think it may be easier/faster
Old Sep 3, 2006 | 10:51 PM
chuckster's Avatar
chuckster
Hey Phil, I have had mine out 2 times... I'll make you a deal..
You install my Clutch and I'll work on your Instrument Cluster..
Old Sep 3, 2006 | 11:04 PM
SpeedyZ's Avatar
SpeedyZ
Pretty simple, I'm sure you can get it in 20 minutes or less. Pretty much all you have to do is remove the center console and the trim under the left dash. Two screws in the top of the IPC and two below. One big wiring plug and the small HUD plug is equipped. You will need to remove the two nuts holding the steering column and drop it a inch or two to get the cluster to clear the steering wheel. But you may not want to follow my instructions, I think I did something wrong! My IPC ended up on the rear diff!!!
Old Sep 3, 2006 | 11:09 PM
SpeedyZ's Avatar
SpeedyZ
Oh, almost forgot!
Warning: Don't lay your IPC face up or face down for more than 15 minutes. It can damage the fluid filled gauges. Store it just like it sits in the car.
Old Sep 3, 2006 | 11:15 PM
Phil97SVT's Avatar
Phil97SVT
Originally Posted by Mike Mercury
Thanks that made it a simple swap.
Phil97SVT's Avatar
Phil97SVT
Thats an interesting relocaton mod.
Old Sep 3, 2006 | 11:16 PM
Phil97SVT's Avatar
Phil97SVT
When you coming up?
Old Sep 3, 2006 | 11:40 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Try this write up for an LED swap it has good removal instructions.
http://www.spdkilz.com/techtipleddic.html
Old Sep 4, 2006 | 12:11 AM
chuckster's Avatar
chuckster
When you coming up?
On my way...
Old Sep 4, 2006 | 05:41 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Phil, Nice pic .... Love your column lock fix method
Old Sep 5, 2006 | 07:19 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
[/QUOTE]
My car !
All I asked you to do was clean the interior
To How to remove the instrument cluster
