Napa slotted Rotors
Old Sep 4, 2006 | 09:46 AM
quimbo's Avatar
quimbo
Default Napa slotted Rotors
Anyone using the napa slotted rotors on there z06? If you are are you happy with them and how much did they cost you? Any feedback welcomed.
QUIMBO SEEYAAAH
Old Sep 4, 2006 | 11:59 AM
BlackZ06's Avatar
BlackZ06
I use the "stock" NAPA rotors and find they perform just as well as the stock ones at a WAY better price.
First time I bought them was I needed a "stop-gap" solution because I had destroyed my front slotted rotors at the track and needed to keep the car on the road until I could get replacements.
I won't name the vendor, but as I'm removing these "expensive" slotted rotors, I realize that the NAPA rotors and these slotted rotors have identical info cast inside the hats ... MADE IN CANADA .... etc.
In other words, the "expensive" vendor was buying rotors from the same source as NAPA and slotting them and then re-selling them. Interesting ... huh?
NAPA slotted must be fairly new, I'll definately try them next time I need rotors.
Thanks,
Steve
Old Sep 4, 2006 | 12:22 PM
1Corvette's Avatar
1Corvette
I believe they are marketed through the United brake line at Napa. They are sold as equal or higher quality than OE. Like the previous post, I have used and sold them for years. Many times, I have found the Napa rotors to be heavier (more iron which makes a better heat sink) and eliminated rotor warping problems. I have found them to be very high quality. Have never used the slotted or slotted and drilled, but would bet they are very high quality and worth the money.
Old Sep 4, 2006 | 01:17 PM
stano's Avatar
stano
I was using NAPA rotors and got tired of cleaning all the rust off of them.
I've since switched to Stop Tech slotted rotors and the rusting problem is non existant
Old Sep 4, 2006 | 03:13 PM
Face's Avatar
Face
quimbo,
How much are they?
Old Sep 4, 2006 | 03:29 PM
quimbo's Avatar
quimbo
Face thats what im trying to find out i have heard $110.00 each for the fronts and $124.00 each for the rears.
QUIMBO SEEYAAAH
Old Sep 4, 2006 | 04:00 PM
bryanZ06's Avatar
bryanZ06
According to the NAPA website they are $61.49 each for the fronts, and $61.99 for the rears.
http://www.napaonline.com/masterpage...ront+-+Hi-Perf
Looks like a good deal for a drilled and slotted rotor.
Old Sep 4, 2006 | 04:27 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
They are $ 65 each. Go to Napa.com
Old Sep 4, 2006 | 04:50 PM
SLPRC5's Avatar
SLPRC5
Take them to a machine shop and have them zinc dipped,,that should work out fine. Just my $.02
SC5
Old Sep 4, 2006 | 05:23 PM
quimbo's Avatar
quimbo
Ok so now that we know how much they are has anyone used them and how do you like them?
QUIMBO SEEYAAAH
Old Sep 4, 2006 | 10:31 PM
Dave68's Avatar
Dave68
QUIMBO SEEYAAAH
You might want to talk to this guy:
http://forums.corvetteforum.com/show....php?t=1490566
And here's what my research turned up:
http://forums.corvetteforum.com/show....php?t=1410305
To Napa slotted Rotors
