Help with a code and an observation...
The car runs fine, no other codes and it does not have any service lights on...I did notice two things:
1) when the codes are present, my passenger window seems to choose when it wants to roll down via either the drivers or passenger switch...and if there are no codes, as in I clear them...the window magically starts working!
**could just be a bad window regulator but strange none the less**
2) I have the F45 suspension option- the controller is located in the rear drivers side compartment...I asked about this in another post- so from those answers, that is what I will call it...anyway, there is a large wire harness that goes thru that compartment out under the car and up around the torque tube then I can't follow it...but there was water coming in the wire harness from under the car and getting the module wet along with the carpet etc...when I say water- I mean you could see moisture on the connectors as well as some around the module itself...
I went ahead and electrical taped everything up as good as possibe, so hopefully this will stop the rain from the rear tire coming in...
so now to my question- if this is in fact the F45 brain, could the above codes be caused by it getting wet? or is this a wild goose chase?
any help or thought welcome!
I was thinking maybe it's because I have some of the options turned off like the horn and lights flash when I lock and unlock with the key fob and autolock-unlock. I have had these codes since I bought the car and never had any problems and they always come back. Have a beer, don't worry.
http://forums.corvetteforum.com/show...ghlight=window
Thank you! I will give this a try! After reading it- I am willing to bet this is the problem!
