I have reset my codes several times in the last couple weeks and have 2 PCM codes that I can't keep off.
One is P0332 which is the rear knock sensor. Im pretty sure I can get this fixed pretty easy.
The second one, I don't even know where to begin. Does anyone have any experience with this code??? Where do I start to fix this problem???
P0337 CKP Sensor Circuit Low Frequency
find the crankshaft position sensor .check for water in connector. any buildup of metal fillings around it . have you done anything to the motor lately. reluctor loose, marks on it like its hitting something
