Had a RPS clutch installed 6 months ago. The installer failed to torque the pressure plate bolts correctly, which eventually lead to a broken pressure plate. Bought a Textraila clutch pressure plate, and billet steel fly wheel. After putting 450 miles on the Tex, I started to get on it a little. I have discovered a pretty bad vibration around 4000 RPMS, this is under a load, 2nd, 3rd, and 4th gears. It is also present in neutral at 3500-4000 RPMS, not quite as bad, but definately there.
Could there be something out of balance or what. The peddle feels great, and it seems to be grabbing good.
Bought the clutch from ECS, and will call tomorrowand see what policies are in place for this type of situation, and if anyone else has had this problem.
Talked w/ Jared from textralia tonight. This guy answered and took my call at 8:30 Texas time. He said they have never had a clutch that used their fly wheel to have a balance problem. He also told me not to worry, that they would get me a new clutch if necessary. The guy seemed really nice and very willing to help. This is a plus. Customer service goes a long way w/ me.
Good to hear the support for the problem with the new setup, what was wrong with the RPS? I have one in mine and I be my mechanic did torgue it right and I have had no issues in over 4500 miles with Sick HP
I think with every C5 Clutch some work great for some customers and some don't. funny how the same clutch in 2 different cars can be like night and day.
Tex clutches come shipped zero balanced and you cant install them wrong because they have dowels that only let you install the PP to the flywheel one way. My Tex has zero vibration issues and drives very close to stock.
Did you use the same installer that didnt torque your PP down correctly? If so I would use someone else next time!
I am using the Textralia, and only went w/ RPS first time because I couldn't get the Tex. at the time. There was nothing wrong w/ the RPS, it was the install. Did not use the same mechanic this time.
We had the tires balacned and discovered one of the wheels are bent. The tech. balanced most of it out. The majority of the vibration is gone. The rest may be attributed to the slight wheel hop from the bent wheel. One thing I don't understand is the slight vibration in neutral. The guy that worked on the car thinks its just the harmonics of the engine. Perhaps it was there before and it just seems worse now.
The motor is a 408. I wonder how much vibration is expected to be felt in the shifter at 3500 RPM's. No vibration before 3500 and clears up around 4200 RPM's.
As of now I'm going to let it go, and enjoy the ride. I think if I'm not careful I will get to focused on problems that may not be there, and not enjoy the car.
I had a year of clutch balance nightmares. Car was pretty close to undriveable. Very frustrating as this happened shortly after I had h/c installed.
When I finally found a shop that knew what they were doing (LG Motorsports), they diagnosed the problem as a bad pilot bearing and bent torque tube. Not exactly sure how the pilot bearing got destroyed (and I mean destroyed) and the torque tube bent, but guessing it was due to an improper install, which sounds familiar to what you are dealing with.
The shop that did the original install tried several times to fix it with no luck. Their end response was that vibration was "normal" from an aluminum flywheel, and "some LS1's are not balanced properly from the factory". Their suggestion was to pull the engine and balance it.
Obviously they were wrong as I have been driving it for over a year and a half with no balance problems since LG Motorsports fixed it.
Just noticed you said your vibrations kick in around 3500, that is exactly where mine did.
Yep that can easily happen. Its good to just let it go and enjoy!
Clutch vibration became more noticeable. Had the car tuned at RPM on Mon., and the tech. there said it was definately a balance problem and was not acceptable. Called Textralia and, Jared the tex. rep. has a clutch in the mail. No arm wrestling at all. Will change the clutch over the week end. Hope that is the end of this. To have a problem is one thing, but to have a problem and no support from a vendor would really be bad. That is not the case here. Textralia has done everything they could to help this situation.
