Remote will not work and yes I changed the battery
Old Sep 7, 2006 | 09:06 PM
rkerr1234's Avatar
rkerr1234
Default Remote will not work and yes I changed the battery
It just stopped working and my wifes did too, any ideas?
Old Sep 7, 2006 | 09:42 PM
108C6's Avatar
108C6
try to resink the fobs by holding lock and unlock buttons at the same time for 15 sec. one remote at a time if that don't work take them apart and clean the contacts and back side of rubber contact points also
Old Sep 7, 2006 | 09:45 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
or you can try re-programing them all together using the DIC, the directions are floating around here somewhere,,, do a search, this has happened before...I'll see if I can dig them up too
Old Sep 7, 2006 | 09:52 PM
rkerr1234's Avatar
rkerr1234
I'm not having any luck with the search
Old Sep 8, 2006 | 12:01 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Ron,
If you have an Owner's Manual the two procedures are in there. Page 2-11 in my 98 OM. It has instructions for synchronizing your remotes and also matching your remotes to your car.
Check the contacts inside the remote and make sure the battery is installed properly.
Note:
If you're free Saturday evening (9th) there is a corvette cruise-in at the Home Depot located at Taylorsville Rd. & Hurstbourne Pkwy. in Louisville. It starts at 6 and goes to 10 PM.
If you're still having problems with the remote we'll take a look at it Sat.
Rock
Old Sep 10, 2006 | 12:20 PM
ISeeRed's Avatar
ISeeRed
Reprogramming is simple: (Make sure you turn the key to the on position first...It is also helpful to close the door and clear any warning codes before starting)
1) Just use the push the option button repeatedly until the screen is blank.
2) Push and hold the reset button until it says programming mode or something like that.
3) Push reset one more time. It will say hold lock and unlock on 1st FOB. Once it learns the code it will tell you to repeat for second, and then the third.
4) It will then enter tire programming mode. Since you do not need this just turn off the key and it will exit programming mode.
Ray
Old Sep 10, 2006 | 07:55 PM
GrayC5's Avatar
GrayC5
See following thread:
Keyless entry not working?
Also, you should be able to find a number of threads on this topic by searching on the key words FOB or Keyless Entry in both the C5 Tech and C5 General sections of the Forum.
Good luck.
To Remote will not work and yes I changed the battery
