Brass headlamp gears
Old Sep 7, 2006 | 10:44 PM
FRED HAMBLE's Avatar
FRED HAMBLE
Default Brass headlamp gears
Who makes the best repair kit for C5 headlamp gears?
There is one on e-bay Rodney's I have heard that Tops Down also make a kit. What is everyone's experience with either kit or is there a third vendor?
FRED
Old Sep 7, 2006 | 10:53 PM
EaglesNest's Avatar
EaglesNest
Default Headlight gear
I used Rodney's and was very happy with it, plus it was $10 less than Mid-America or the other big vendors.
Old Sep 7, 2006 | 11:02 PM
chuckster's Avatar
chuckster
FRED
Rodney... the only way to go... I just did both of mine..
Old Sep 7, 2006 | 11:03 PM
FRED HAMBLE
how easy is the installation?
Fred
Old Sep 8, 2006 | 01:47 AM
jdmvette's Avatar
jdmvette
Night Owl for life
if i was to do it over again, i would use brent franker's gears. there's no rubber BS to get chewed up like the new rubber did with my rodney kit.
http://www.bfranker.badz28.com/headlightfix/index.htm
Old Sep 8, 2006 | 12:56 PM
JC in XTC5's Avatar
JC in XTC5
After considering this, I still went with Rodney's. In my view the rubber serves a very important purpose by absorbing the shock of the motor arm hitting the stops. Otherwise that force is being exerted on the plastic stops and the electric actuator itself.
Also, after over 6 years my original rubber was still basically perfect, so under normal use they shouldn't get chewed.
I just did the gear install last weekend and it worked great.
Old Sep 9, 2006 | 11:13 PM
FRED HAMBLE
Thanks for the input. no one has used the gears from Tops Down Why?
The jury is still out as I only had two responses and they are split.
Can I get some more input?
FRED
Old Sep 10, 2006 | 09:34 PM
FRED HAMBLE
ttt
Old Sep 11, 2006 | 02:24 AM
The Batman's Avatar
The Batman
I used Rodney's old kit that didn't include the T-braces, just glue. After a couple of glue failures, I re-visited Rodney's site, exchanged some email, and asked for and ordered just the T-braces from the new kit. He sent glue, T-braces, and a replacement rubber piece for one that got mangled. I'd give him more business, if I could.
Old Sep 11, 2006 | 02:42 AM
jbauch357's Avatar
jbauch357
I installed the kit from Rodney and it was perfect. It came with everything that you need to rebuild the motor including the gear, rubber bushing, internal spacer, silicone, epoxy, t-bar with plastic bushing, and it even came with a stir stick for the epoxy! I highly reccommend it and when my other gear goes TU it will get the exact same kit.
Old Sep 11, 2006 | 12:18 PM
SpeedUp's Avatar
SpeedUp
Old Sep 14, 2006 | 04:30 PM
webstars28's Avatar
webstars28
2nd Gear
Default Headlight Motor
Head light motor makes a really loud noise when it closes. How can I fiix this would replacing gears work.
Old Sep 14, 2006 | 05:11 PM
Z O SICK's Avatar
Z O SICK
These gears would solve your problem. I went the cheap route and got my "stock" gears for $10. I'm sure they will go out again but at only $10 it's not that bad. PM if you want the link and part number. They are not a sponsor on here.
Old Sep 14, 2006 | 05:19 PM
LoneStarFRC's Avatar
LoneStarFRC
A couple ways to help lengthen the life of your stock gears:
1. Lube the headlight linkages once a year when you're lubing all the other lubing, i.e. hood hinges, door hinges, etc.
2. Guys living in northern climates (read as ice/snow) always make sure you clear any and all ice and/or snow that may accumulate before raising the headlights.
3. I don't care how cute or sexy they are, never ever let a Hooters Girl (or anyone else for that matter) sit on the fender/headlight door.
Old Sep 23, 2006 | 09:05 PM
xrayal48's Avatar
xrayal48
1st Gear
Default Rodneys Headlight Gear Repair Kit
Can You Please Tell Me Where I Can Purchase Rodneys Headlight Gear Repair Kit To Fix My Noisy Headlight. I Could Not Find It On Ebay. Is There A Web Site, Thanks
Old Sep 23, 2006 | 10:19 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
I also installed Rodneys gears. Very happy with the results. Fairly easy to do. Here is the link to Rodnets web site.
http://www.rodneydickman.com/corvette.html
Old Sep 24, 2006 | 06:11 PM
chimazo's Avatar
chimazo
The kit on the TopDown website looks IDENTICAL to Rodney's kit, so I am willing to bet they are one in the same.
Old Sep 26, 2006 | 10:00 PM
FRED HAMBLE
ttt
To Brass headlamp gears
