Check Engine light?
Old Aug 30, 2006 | 03:58 AM
Spoon83's Avatar
Spoon83
Default Check Engine light?
I recently popped a check eng light while driving to work. I drove around with it on for a couple of days, while i was waiting for my AeroForce Tech gauge to come in. BTW, this gauge is great. Hooked it up and it shot out two codes: P0102 and P0440. Does anyone have any info about this and what is the fix?
P0102: Mass or Volume Air Flow Circuit Low Input
P0440: Evaporative Emission Control System Malfunction
2000 Mill Yellow C5, 6spd, 74500 miles
Thanks in advance!!!
Old Aug 30, 2006 | 09:52 AM
muncie21's Avatar
muncie21
sounds like you may have a dirty or bad MAF.
Old Aug 30, 2006 | 05:19 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Why do you need an aftermarket code reader??? There is one built in to your C5!
This is the absolute best C5 Code web site!!! It tells you how to read the DTC's and what they are!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
[www.corvettedoctor.com
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
Here is another very good site:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Try cleaning your MAF sensing wires. You can use a good MAF spray or, I just use BRAKE PARTS CLEANER!
Just spray it on, let it evaporate and that should take care of it! MAKE SURE that the ducts betweem the MAF and the TB are sealed 100%.
The other code is most likely a dirty AIR system check valve. The on e for the drivers side is a snap to change. The other one is behind the head and will most likely require you to remove the intake to replace it. I used a spray and some compressed air to clean mine inplace and it was 100% effective!
BC
Old Sep 2, 2006 | 02:17 PM
Spoon83's Avatar
Spoon83
Hey thanks alot guys. I will try to get to it asap, but i have a bigger problem now, Steer Column Lock.
Old Sep 2, 2006 | 03:01 PM
Wake Champ's Avatar
Wake Champ
click on search in the upper right corner
Old Sep 2, 2006 | 04:17 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Whats the condition of your battery??? A low battery can contribute to the column lock issue. Disconnect the battery, charge the battery and reconnect the battery. Clear any DTC Codes and see if you still have the problem/
BC
Old Sep 2, 2006 | 11:12 PM
Spoon83's Avatar
Spoon83
Whats that supposed to mean?
Old Sep 26, 2006 | 08:43 PM
Z QQH 6's Avatar
Z QQH 6
Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I also have just been flashed with the P0440 code. The Evap system. What will this involve? Is it assumed the AIR pump is shot?
Old Sep 26, 2006 | 10:07 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
No, its usually not the pump but all the other stuff in that system.
BC
Old Sep 26, 2006 | 10:18 PM
Z QQH 6's Avatar
Z QQH 6
Senior Member
Cruise-In V Veteran
I guess I'll be checking in the morning from the pump back thru.
To Check Engine light?
