LS6 Heads worth the effort?
Old Sep 8, 2006 | 11:53 AM
cam99's Avatar
cam99
Default LS6 Heads worth the effort?
A guy at Thunderracing said that I'd probably get about 10rwhp if I swapped my heads (LS1) for LS6's?
What do you think?
I just put in a Cheatr Cam and am planning on the LS6 Intake.
I have Headers (shortys) and ported Throttle Body.
Old Sep 8, 2006 | 12:09 PM
Turbosixx's Avatar
Turbosixx
Do a search on ls1tech, someone put a set of stock ls6 heads and picked up like 30hp .
Old Sep 8, 2006 | 03:00 PM
zeevette's Avatar
zeevette
Yeah, you'll get at least 20-30 rwhp out of stock Z06 heads with the sodium filled valves.
Old Sep 8, 2006 | 10:55 PM
SLPRC5's Avatar
SLPRC5
What do you think?
Yeah buddy..check my sig. My LS1 has 2002 LS6 heads and cam, while doing that change oil pump to a LS6 oil pump and timming chain. I had an SLP UD Pulley installed also, Ported LS6 TB, A LS6 intake. Went to a FAST intake later and long headers, haven't had it dynoed since the FAST and LT were installed. Those dyno numbers in my sig. are with your setup running shortie headers.. 349. RWHP and 351 RWTQ 3.15 gears '97 A4
Not bad. AFR is 12.5
Old Sep 8, 2006 | 11:32 PM
msghuff's Avatar
msghuff
heads on a corvette is an easy swap, mill the ls6 heads slightly and run a .040-.045 cometic gasket and you might be impressed with the power you make over the entire RPM range. I would guess 25-30rwhp
Old Sep 9, 2006 | 12:12 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
If your gonna do it, do it right. Have the heads ported to closely match the cam profile. have it done by thunderracing since they are the vendor of your cam. Your car will be kick ***! To make a heads and cam setup work, you need to make sure they match each other to the T!
Old Sep 10, 2006 | 05:17 PM
cam99's Avatar
cam99
Thanks for the encouragement. I already bought the heads, but the guy at Thunder kind of had me bummed when he said only 10 rwhp!
Old Sep 10, 2006 | 07:02 PM
AU N EGL's Avatar
AU N EGL
LS6 heads are great, now what cam will you add??
Old Sep 10, 2006 | 07:07 PM
msghuff's Avatar
msghuff
I think you got this backwards.... You buy a cam that will compliment your heads not port the heads to match the cam
The LS6 heads are great and with a mild cam you can see over 400 easy.
Old Sep 11, 2006 | 09:30 AM
George V's Avatar
George V
I installed the GMPP Z heads with a small cam; the results were 400HP with 387 FT/LBS at the wheels. Get the heads ported and deck them, you will be happy
Old Sep 11, 2006 | 01:57 PM
cam99's Avatar
cam99
Afraid of valve to piston clearance, does anyone know of a place on LI, NY for Porting& Polishing?
I just finished putting in a Cheatr cam and now I found LS6 heads I want to put on with a LS6 intake.
I really don't want to go through any more expense to p&p, think its stupid? Can't find someone local to p&p. Looking into maybe porting them myself?
Old Sep 11, 2006 | 02:55 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
I'm in the same boat.
Old Sep 11, 2006 | 04:44 PM
Bad Machine's Avatar
Bad Machine
From: Rude, Loud and Aggressive! ECS Twisted Racing, "How fast do ya wanna go?"
ECS just did P/P TEI LS6 heads w/ .920 springs, G5-X3 cam. High dyno pull today while tuning was 471/410!
Old Sep 12, 2006 | 08:01 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
thats crazy power
Old Sep 12, 2006 | 08:04 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
TEI or TEA??? I've never heard of TEI before.
Old Sep 12, 2006 | 04:39 PM
Bad Machine
TEA, Total Engine Airflow. Sorry bout the typo.
Old Sep 13, 2006 | 08:25 AM
cam99's Avatar
cam99
How much can they be milled?
To LS6 Heads worth the effort?
Old Sep 13, 2006 | 09:15 AM
msghuff's Avatar
msghuff
I would take them down -.024-.030
Old Sep 13, 2006 | 04:25 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
MSG Huff is the man! He needs to come down to Augusta for the next CC race as there a few 402 A4s that need a fast car to run (mine is not there)
Dave
Old Sep 13, 2006 | 08:34 PM
madeouttaglass
Senior Member
Cruise-In V Veteran
I assume you need different length pushrods then?
