A few years back, a CF member (Yo-El) was one of the first members to install an oil catch can. If I remember correctly, he found that his 1/4-mile times suffered noticably and he subsequently removed the catch can. His times immediately improved and he advised everyone to NOT use the can.
My question is this? Has anyone checked 1/4-mile times before and after installing a catch can? If so, and your times worsened, what did you do? I can imagine that if flow is restricted, performance could suffer, but it's unlikely that anyone knows the flow rate that is necessary for unrestricted performance.
Thoughts, comments, input?
Your kidding right? There is no way that a properly installed catch can could have ANY measurable detrimental effect on performance.
Pull off your intake manifold... then look at all the oil... then tell me it's a fad. If you run these cars hard like at an HPDE like I do then they suck oil into the intake tract, yes most is burnt off but I didn't like what I saw at all.
That's why I have a new elite engineering black catch can on the way.
Furthermore, a properly designed catch can doesn't impede vapor flow at all and the PCV gasses excape fine.
I installed them this past weekend in both my GTO and my Z. I have not tested the Z yet, but just with spirited driving at both ends of my 50 mile commute I had at least a teaspoon of oil in the cans. Can't tell me it is a fad.
I see no possible way this could hurt performance. The PCV system is a vent for crankcase pressure. It has no bearing on performance that I can see.
I think a properly installed catch can will improve performance over an improperly installed one. The PCV is there to vent gases and also provide some vacuum to the crankcase. This vacuum has the effect of sealing the rings better which will give better performance. Additionally, having no oil in the intake means no goes into the combustion chambers to cause your pistons to act like bbq coals. Therefore it reduces the possibility of pre/post ignition which WILL rob power.
I remember that vividly cause after a month or so of that debate I was at the dyno and took the CC out on consecutive runs. The results were within a single HP as I remember. Basically no difference.
I posted that at the time but have not tried to go back and find it.
Drag runs IMHO contain too many varaibles.
There have been literally hundreds of members install the cans with no problems. I think the very few instances of poor performance has to do with unrelated problems that happened at the time of install.
Actually the catch can in question was a MOD... using the Campbell and Hausfeld Compressed Air Filter.
What was happening is the stone element inside was actually restricting airflow. I was able to actually prove this by running an Autotap and monitoring Fuel Trims during Idle.
With the restrictive element installed the Trims went WAY Negative.. (-8 to -10) which meant the lack of additional air normally coming in from the PCV was gone.. Therefore causing a rich condition and making the PCM pull fuel (going Negative)
After I pulled the element... The trims went back to a normal (-2 or -3)
It was repeatable.. I pulled the filter element as it is not needed to still catch oil.. mine is currently 1/4 full.. I usually get 1/2 full between oil changes...
Not quite sure why there would be a problem at the track..
What I intend to use is a coalescing filter. This type of filter is specifically designed to trap oil and moisture. They are commonly used to prevent oil and water from entering anything that performs better without it - electronic instruments, pneumatic cylinders, etc. Of course, each of the various sizes of this type of filter has a flow rating. Under-specify and you will restrict flow. You can always take the hammer approach and simply cram in the largest one you can, hoping it is adequately sized, but that's not aways a smart thing to do.
Thus - my question about whether anyone knows the flow rate through the hoses in question.
Two thoughts;
If you're planning on running this mod, couldn't you just adjust the fuel trims at idle to compensate (like you would any other mod?)
I would think that the affects at anything other than idle would be minimal. Once the TB opens, the airflow from the PCV system is insignificant
I left my element in, because I was concerned that once it accumilated enough oil in the bowl, the vacume would simply pull it out of it and into the intake as before
Interesting. I would not have expected it to affect the fuel trims. Wonder what blocking it off completely like the post that started this thread would do. In my installations, I took the stones out up front, since I figured that oil vapor would be easier to condense out of the air than water and figured it would be unnecessary. Based on your results, I don't know if I should call my choice luck or divine intervention...
What is puzzling is that even the CH filter has a max flow rating. Removing the stone element may raise that rating, but I wonder why the original assembly had insufficient flow. Most coalescing filters start at 20 CFM. That is alot of flow. Perhaps the stone element was faulty from the factory?
Those stone elements are designed to remove water and not oil, I would imagine it would clog pretty quickly. Another factor could possibly be pressure. When you flow 20 CFM at 90 PSI, that is bit different than the PSI in the PCV system. The highest level of vacuum I have ever seen is about 25-30 PSI. I have no idea how much crank case pressure could build. It would vary based on the compression rings, but if it built too much say goodbye to the oil seals. The front and rear mains would probably go first.
Good point. The other thing to consider is that the filter in question is probably at the very low end of quality and performance. I will be talking to a high-end manufacturer about low flow/low pressure applications, very soon. Even at the high end of coalescing filters, the cost is still weel below that of the catch cans I've seen.
Thanks.
Real catch cans do not use filters, and they work as well as the CH and other which are designed as moisture seperators. Years ago I ran a CH and it kinda worked then I took the element out of it and it worked just as well. All this catch can stuff only works to a certain extent. You can put six of them in line and still have lots of oil in the intake.
