Need help lowering C5
Old Sep 10, 2006 | 08:37 PM
rdny74's Avatar
rdny74
Default Need help lowering C5
Tried to lower front end of car with stock bolts. I read that you should turn bolt with 10mm wrench counter clock wise to lower the car's front end on stock suspension. But the bolt doesn't move. Am I doing something wrong? How do I lower the front end with the stock bolts? Please Help!
Ok tried to lower bolts in front but they won't budge. The threads are stripped. The washer on bushing looks welded to thread. Is that how its supposed to be? Should I cut the bolts and buy new ones? Please help
Old Sep 10, 2006 | 08:49 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Try relieving some of the spring pressure by jacking lightly on the spring with a floor or bottle jack, using a wood block to spread the load. You want to be outboard of the spring support clamp (see below), as close as possible to the bolt.
Spraying the bolt threads with WD40 or penetrating oil probably wouldn't hurt either.
Old Sep 10, 2006 | 08:57 PM
Old Rotor Head's Avatar
Old Rotor Head
I think your also dealing with a left hand thread. It's been 3 years but I think I turned it ccw.
Old Sep 10, 2006 | 09:49 PM
VetteTech81's Avatar
VetteTech81
the bolts could be siezed to the spring.. I see it all the time with the earlier C5's 97, 98, 99 ect.. they are right in the wheels wells where water from rain and washing gets into the threads... you can put some penatrating oil on the threads, let it soak, take the load off the pushing by loading the spring as shown above.. and hope for the best..
You can't really heat the studs since the spring would melt... So it leaves you with little options..
Good Luck..
-=Rick
Old Sep 10, 2006 | 10:11 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
the left hand thread is urban/forum legend; ccw is correct, as noted, remove pressure from spring and spray threads with PB Blaster
Old Sep 10, 2006 | 10:21 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
but if you've never seen the other end of the bolt, it's easy to understand why people think it is reverse-threaded.
Old Sep 10, 2006 | 10:40 PM
horsepawere's Avatar
horsepawere
5th Gear
I did the same yesterday, i lower mine, using the stock bolds.
do not jacked the suspention up, lift the car without lifting the suspention and turn counterclock hard..hard it will turn.
good luck!
Old Sep 11, 2006 | 03:04 PM
rdny74's Avatar
rdny74
Default lowering c5
i still can not get the bolts loose to drop the front of the car.what do i do if there are stuck. please help
Old Sep 11, 2006 | 03:50 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
If you have followed all the advice here and still can't get them to budge, I think you only have two options left.
  1. If you are feeling lucky, slip a length of pipe over your 10mm wrench, to gain a leverage advantage (i.e., use it as a breaker bar). I have never heard of anyone breaking the bolt, but...do this at your own risk.
  2. If you're not feeling so lucky, go to an alignment or Corvette specialty shop that does corner weighting, and tell them you also want the car lowered. Adjusting those ride height adjustment bolts is part of the procedure (thus it becomes their problem).
GL!
Old Sep 11, 2006 | 04:32 PM
SteveDoten's Avatar
SteveDoten
6 pt. 10mm wrench; 12pt. not good
Old Sep 11, 2006 | 08:03 PM
Jay-rod's Avatar
Jay-rod
I had the same problem even with a 6 point socket and bar wd40 .Stripped the head of the bolt.I butchered the bolts and forced them with a pipe wrench then cut the butchered area of the bolts off.JER
Old Sep 12, 2006 | 01:44 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
There's just not much surface on the head to take the torque. Make sure it's free from the A arm. If you soak the bolt enough it should come free, just make sure you use a 6 point socket.
You can always pull the spring out to get better access.
Old Sep 14, 2006 | 08:02 PM
rdny74's Avatar
rdny74
Default Still Need Help
Old Sep 15, 2006 | 01:27 AM
Vette_Fan's Avatar
Vette_Fan
Default Lowering the FRONT
Just to add to the thread, can someone suggest an easy way to cut off those bushings in the front. I think there are 3 of them, and we can easily get rid of one and live with just two. Would that work fine, or create any kinda problem. (Cutting the bushing would be after its lowered all the way to last 2 threads on stock bolts in front.)
To Need help lowering C5
