Halltech trap intake install
Sep 10, 2006 | 09:20 PM
Do I need to cut the fan shroud. I bought this off of another guy and I cant get ahold of him. He is a pic of the intake I got.
Sep 10, 2006 | 09:32 PM
No cutting required. You do need to remove the lower bolts of the shroud under the front bumper and move things a bit to fit the filter and tube. The MAF goes between the two tubes.
Sep 10, 2006 | 09:42 PM
Quote:
Ok thanks, I just tried to put the one piece on but I will loosen the bolts and slide it down there.
Sep 11, 2006 | 10:21 AM
Don't for get to install the Z06 screens and cut out the fog light plastic so that cold air gets in there better!!
Sep 11, 2006 | 08:29 PM
Quote:
This is on a 01 zo6....
Sep 12, 2006 | 04:39 AM
i have the same system i just bouht it from another CF member also
let me knwo how the install goes i need to install mine also
Sep 15, 2006 | 08:07 PM
Do you have to relocate the ABS sensor that is down there or does it fit under that???
Sep 16, 2006 | 11:00 AM
Quote:
cut some holes in the plastic anyway - you just don't need to buy the screens
Sep 16, 2006 | 11:00 PM
Quote:
I meant to say air bag sensor not anti lock brake sensor. There is some sensor down there either way did you relocate it or does the trap piece fit under it?
Sep 17, 2006 | 12:30 AM
I have a video of the install procedure that was on the Halltech website.Send me your email and I will send it to you.
rnunez@wideopenwest.com
Sep 19, 2006 | 11:00 AM
senosr relocation??? anybody???
