Performance increase on '99, MN6 from Hypertech PP??
Old Sep 12, 2001 | 09:02 AM
Gramps's Avatar
Gramps
Default Performance increase on '99, MN6 from Hypertech PP??
Anyone out there use a Hypertech Power Programmer on a '99 with the MN6 transmission? Any advantage or performance gain?
Old Sep 12, 2001 | 09:47 PM
Gramps's Avatar
Gramps
Default Re: Performance increase on '99, MN6 from Hypertech PP?? (Gramps)
Help! Someone???
Old Sep 12, 2001 | 10:00 PM
C5Cemo's Avatar
C5Cemo
I tried one when they were first available and all the power tuning did was make the engine detonate thus losing power... I had already removed the MAF screen, though.
The only good thing it offered was fan temp. reprogramming for a lower temp. thermostat but that wasn't good enough to justify the cost.
Old Sep 12, 2001 | 10:24 PM
CCrane65's Avatar
CCrane65
I use one on my 2000 and I will admit that I had detonation at first but we only have 91 octane gas here in Wichita. So I put 2 bottles of octane booster in the tank (not the cheap stuff, the off-road stuff) and not only did it cure the detonation, it allowed the engine to fully utilize the new air to fuel ratio to drop my 1/4 mile et from a best of 14.59 to 13.81 and my top speed from 98 mph to 103 mph. Was it the octane boost only? Don't know for sure but I seriously doubt it. If for no other reason that the fact that I also raised the rev limiter to 6400 rpm which is 200 rpm above the factory limit. I was only able to get one run in that day (September 1st) but it was a good one for me. I will make another run soon without the HPP III but with 2 bottles of the same booster and see what happens.
cc
Old Sep 12, 2001 | 10:37 PM
thekev_2000's Avatar
thekev_2000
I used mine when I installed my lower thermostat and noticed a little SOP improvement. I did not notice any detonation and already had my Halltech installed with MAF that they offer. I liked the ability to adjust my rev limiter and fan speed, when you weigh everything it is a fair investment depending on how mod crazy you plan on going.
Old Sep 13, 2001 | 10:14 AM
ncvetteman's Avatar
ncvetteman
Generally, no or little HP gains. Mainly used to inprove the shifting characteristics of A4s and adjust for different gears.
To Performance increase on '99, MN6 from Hypertech PP??
